bihon
- May 3, 2009
- Age
- 63
PC: ubuntu
DM600pvr
- NL
Hello,
Unfortunately my 600pvr comes without usb connection, so I would like to insert my usb smartcard reader (smargo) into a PC on the same lan and connect it to the receiver. Up to now I have established nfs connection, exporting /dev directory from PC and successfully mounted it into /dev/smart/ in the DB, however /dev/smart/ttyUSB0 is not recognized as a smartcard; Entitlements message says:
card reader /dev/smart/ttyUSB0
no or unknown card inserted
It works correctly in the PC.
PC:
/etc/exports:
/dev 192.168.1.7(rw,async,no_root_squash,fsid=5)
mount command in dreambox:
mount -t nfs -O rw,soft 192.168.1.8:/dev /dev/smart
Any ideas?
PC:
/etc/exports:
Any ideas?
