Nicostar Software
Abdelimy
Hello,
I've got a Nicostar 460 Surprise, it is flashed. But I don't know where to find software for it. The HW version is 0129 and the SW Version is: S2_V1.5.5
Please can anyone help me?
laziz
Abdelimy said:
Hello,
yes the same problem here
how is it possible that ther no info about this recievers ?
and no where to find firmware for it or upgrade ?
or the dealer of this recievers doesnt knew anyting about those recievers
laziz
tu n as ka casser ce tas de merde qui ne te servira jamais
can you do it in english ?
tamazgha2003
dreambox 500s
tamazgha
i have firmware for this receeiver but i dont no how to actived the keyeditor(patch)
FRED14
il faut aussi le programme de communication entre le demo et le pc pour pouvoir le flasher!
met le firmware en ligne !
tamazgha2003
dreambox 500s
tamazgha
go to http://satbox.spectranet.tv/ al that you need is there,if you now how to get in the keymenu please reply(si tu sais comment entre dans le keyeditor metz le ici svp)
samymy
for Nicostar 460srprise look at the receivers golden interstar 8005 HW 129V188B2P186 date 18/12/04
FRED14
le soft n'est pas bon , rien ne marche et en plus il n'y a pas de keyeditor !!!!!
tamazgha2003
dreambox 500s
tamazgha
we need to active the keyeditor and i dont no how
Sopranosat
i have the same problem with the nicostar 8005 ci matrix...i don't find any firmware or soft for it...if someone gimme some council thanx for all..
tamazgha2003
dreambox 500s
tamazgha
at last i find the code how to active the keyeditor and the patch for nicostar 8005
and probaly may work for 460 surprise
Sopranosat
how pliz
soprano sat
tamazgha2003
dreambox 500s
tamazgha
Menu-----system Setting---ok---0571
bengates
Salut,
Merci pour vos messages.
J'ai un nicostar 8005 CI, normalement flashé mais je n'arrive pas à capter TPS.
Je n'arrive pas à ouvrir le Keyeditor, en effet quand je vais ds menu --- menu setting - je peux seulement choisir la langue et d'autre settings...
Ma version SW = 1.88b2 et HW = 207 est ce que mon recepteur est vraiment flashé?
Merci d'avance
nacerfahmi
une fois dans system setting tapez 0571 sur la telecommande et vous allez voir un bouton rouge en bas de la page . voilà , l'emulateur est activé et bonne vision
bengates
Merci Nacer pour ta réponse.
Ca marche bien.
Est qu'il est possible de récuperer (lire) le firmware du modulateur ? si oui Comment ( y a t-il un mini tutorial upgrade 3.2 ? ) ?
Bon week end
