nilesat 301
Dish 90cm, Inverto, StarSat
Iraq
Nilesat 301 supports this Frequency Range
11700-12500
The same frequency on Nilesat 201
Iraq
Simply
Nilesat 301 will replace Nilesat 201
in 2026 or next years
Hama1919
Tunisia
I have a feeling, which may be right or wrong, that the official commercial operation of the satellite has not yet begun.
The issue of transferring some frequencies to the new satellite and to the Eutelsat frequencies is only part of maintenance work on the old moon and practical tests for the new satellite.
The process of transmitting frequencies according to previous information I have will be according to a plan to equalize the current frequencies between the two satellites. Perhaps this will happen before the end of July. As for the previous appointment, my estimate was not firm. I expect the transfer process will be of an official nature and will be officially announced via Nilesat.
This knowledge is with God Almighty.
Iraq
FlySat & LyngSat updates for Nilesat 301
Not Correct
I will try to remedy this misinformation
Some freqs on Eutelsat 7 West A
Hama1919
Tunisia
The frequency 12418 is still on Eutelsat 7 West A, and it has not been transferred to Nilesat 301
Hama1919
Tunisia
Du withdrew from Nilesat and joined Eutelsat at 7° West
the du move 201 to eutelsat ?
Iraq
A year or more ago, du transferred/moved its frequencies/servies from Nilesat 201 to Eutelsat 7 West. It terminated its contract with Nilesat permanently.
So, it is impossible to come back to Nilesat.
The same thing with beIN
Iraq
Do you receive the signal of this frequency in Europe 12728 Vertical 27500
5/6
DVB-S/QPSK
Eutelsat 8 West B @ 8°West
East Beam
Hama1919
Tunisia
I and Mr. AhmedIraqi updated the frequencies 12322 V 30000 and 12418 H 30000 On Eutelsat 7 West A (E7WA)
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
It looks, like there is no video possible on 2,2m in southwestern of Germany on DVB-S signals from Nilesat 301.
Iraq
Check FlySat & LyngSat out Now :-respekt:-respekt
Manikm909
Small'ish Dish Man
Kent, UK
back in the day - everyone tried to get SHOWTIME Sports on 7w - i think it was the H transponders that were tricky to catch.
are there equivalent frequencies just as hard to catch from the UK now ? there are two MBC2 channels i can get, one is much stronger than the other. (as an example)
Iraq
MBC 2 you mean on Eutelsat 7 West A @ 7.3°West
You can try to catch this freqs as an example
11996 H 30000
11881 H 30000
11727 H 30000
12073 H 30000
12034 H 27500
OSN Mux
msanifu
hooked up on ses 5 nss12 arabsat
kenya
Yes it's on 11938v 27500 and 11471v 27500-8west
