Nokia 9800S Need help Please
Medhat Samir
I have a reciever Nokia 9800S, suddenly it is displaying the start up message and keep rotating it , also there is acode A20, it is not operating and remote control has no effect.
I have cut off the power many times and turn it on again, but nothing happened, the installed software is MA 2.00 since 2 years.
Any body can help please???
Thanks in advance
Medhat
kl0
mediamaster 9800s
egypt
i have the same problem, and i don't know how to fix it
Medhat Samir
Dear all,
I have sent the receiver to the maintenance, they have fixed it, They have cleaned the Flash memory (as they Said). However I have discovered that I can not save more than one Satellite with my motor antena. if I want to move from Satellite to another I have to reconfigure this Satellite.
Anybody have a solution?
hazim
hi...
do you have master code of this model nokia 9660 s , please?....
