Nokia Mediamaster
MasterAbacus
Visit site
Yorkshire
Does anyone know what is requred to upgrade the Nokia mediamaster 9850 to a Mediamaster 9600...
I understand theres a Firmware, and hardware upgrade required....
Swedish sam
Well, the DVB9850T is a terrestrial box, originally designed for ITVdigital, and the DVB9600S is a FTA satellite box.
So you would need to change the tuner module, the frontend,the software, the remnote control, in short everything.
Better to try & buy a DVB9600S 2nd hand!
Good luck
Swedish Sam
fody
Nokia 9400S
Windows XP
Ireland
Does any one know the default PIN code for Mediaster 9400 S!!!! thanks for ur support.
HB13DISH
Retired Mod
Middle East - Israel
Try 1234
It works on 9800S
fody
Nokia 9400S
Windows XP
Ireland
well done, thanks man.
