Non-Digiboxes for Astras
jortheo
From The Sunny Place
www.jortheo.net
Humax 5100
Larnaca, Cyprus
I have a question, is it possible to receive the FTA channels on the Astras without a digibox i.e. using a Humax for example. And if it is possible which receivers are recommended?
Bare in mind that I live in Cyprus.
Of course it is.
Anything with a sensitive tuner seeing how far away you are.
Dont forget you still wont get the Astra 2D unless you have a big enough dish.
dave branson
Florence Italy
Most Korean manufactured receivers seem to have the most sensitive tuners.
BadWithComputer
The Local Drunkard
30MB ADSL ONO, Spain
32" Internet connected TV
Many Satellite Dishes.
Humax HD Freesat Box
Spain
is there any kind of marking on FTA box´s so you can tell if it is more sensitive than another?
dave branson
Florence Italy
Dont think so,thats the problem,I am in a fringe area and have tried lots of receivers and LNB,s,from expensive ones like Triple Dragon and Manhatten,receivers and SMW LNB,s to cheapo,s like SAB 710 ci and Inverto
LNB,S most are crap,suprisingly the more expensive ones.
The best reception I get on Astra 2D is with a SAB receiver and an Invacom
quad LNB on a 1.8 IRTE pf dish.
A lot of it is trial and error.
spiney
Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!).
Midlands
But, remember that with non-Sky boxes, there's:
1) No epg information.
2) No text services on BBC/ITV/(Sky news) channels (apart from teletext subtitling on BBC), due to proprietry system. Otherwise, there's "standard" teletext on some Sky channels even without decryption - eg some sports - and CNN has a full text service.
3) Channels come and go, and without the Sky epg system you'll have to regularly "scan" for new channels, which is much easier using a "blind scan" capable receiver.
rikksow
Huge great Dish in Cyprus
Tomb Of the Kings
Also bear in mind that in Larnaca you will require at least a 3.7m dish in Larnaca to pick up BBC & ITV, without that there isn't really much worth watching on FTA.
To correct this slightly - theres certainly basic epg info on a lot of the fta channels because I can see it on my fta box connected to the second 28E feed on my dish :)
digi24
Fixed reception from: *28*19*16*13*9
*Panasonic TUDSB40*
*Topfield 5000 PVR*
*Humax HD1000*
*Sky Digital subscription*
*Dragon 4.1*
*T-Rex supermodule*
*Diablo 2.3*
*Diablo 2*
*ADSL 24Mbps*
Athens/Greece
True AS. I have a FTA box for the BBCi-streams of Astra 2B and I do get EPG info for M&M.
jortheo
www.jortheo.net
Humax 5100
Larnaca, Cyprus
There is already a large dish in the building which services successfully a Sky subscription.
Cupart
Why not get a used PACE 2600 or DN430?
You can get them quite cheap on eBay
Zorba
3m(28.2E),1.5m(19.2E.13E,10E),1m (4W ,7W)1m (?).diseqc 10,sky plus,VU+,telergy iptv.
Satlook nit colour + Horizon hdsm.
Limassol, Sunny Cyprus
Do you know if the dish receives bbc or itv?You are better off getting a sky digibox with a ftv card as this would give you ch4, five and sky three because a fta receiver will not :)
swiss_rocket
Member on the piste
70 cm dish + Pace 430 on 28.2E
NW Switzerland
Hi all,
Thought I would join this thread, as my Panasonic DSB30 is on it's last legs and I was also wondering what to replace it with. I have a standard Sky 45cm minidish and reception is usually okay. If I choose another receiver, could I lose signal quality?
Zorba
first choice pace 2600,if you can find any ,or the current pace d430.
swiss_rocket
Member on the piste
NW Switzerland
Thanks for the suggestion Zorba. What makes the 2600 worth the extra £70 or so?
spiney
Midlands
Some 28E channels do have now/next info, that's true, but otherwise nothing, certainly not a 7 day epg (because - for Sky - that's all on the proprietry epg).
Where there's teletext, that can have prog listings, eg CNN, TRAVEL, etc.
Zorba
If you put the 2600 side by side with the 430 and you are in a fringe area,the 2600 is better eg if bbc is pixellating on the 430 then its fine on the 2600(in my experience)
dxsat
skyinmadrid.com
Snap's setup: (In Spain) Humax HDR, Prodelin 1.8m dish + Invacom QDF-031 + CM feed, (In UK) CallFlow VDSL + EE 4G, Sky Q, YouView HD, Mac OSX, iOS
UK: Tonbridge, Kent. Spain: Madrid.
The 2600 has a better tuner but is slower than 430n. Can make a big difference in really weak signal areas.
I've put a couple of entry level FTA boxes in for customers here in Madrid and they were both less sensitive than a Pace. After testing two Pace boxes on a quad LNB, I tried a Technomate 1000 and it was very poor on Astra 2D, no picture at all on BBC 10847 V, whilst the Pace produced a perfect picture with no defects at all. I would hope that more expensive FTA equipment would be better, but I wonder if that is the case...??
swiss_rocket
Member on the piste
NW Switzerland
Many thanks for the input Zorba and snap :cool:
I have ordered the Pace 430 from _www.thedigiboxshop.com :)
spiney
Midlands
Meaning of this not clear!
Does it mean a communal system (multiswitch), in which case you could just "join on" your own Sky receiver?
Or, is it somebody's private installation? In which case - since already working - perhaps you could "share" the dish by using a dual or quad type lnb and running a 2nd cable? Would save installing a 2nd large dish!
