mogg
- Aug 11, 2004
- Age
- 61
Usual Grundig digibox
mesh pc+toshiba laptop
wireless router
Technomate 7755, Triax 85cm dish, Manhattan DiSEqC 120 H to H motor all still in box
- essex
hi all,
I hope you can help me, I have be pesuaded by a friend at work to go down the motorised dish set up and have bought a Technomate 7755 with a triax 85cm dish.
Now being a complete plonker a didnt think where about I was going to mount the dish! . I have a south facing rear garden ....fine, but the problem is that my house is of the dormer style and I have no verticle surface for a wall mount. mounting it on the ground or on the side of the house is not an option.
So this leaves me with the option of a roof mount on top of the rear dormer. this will be ideal, it couldnt be seen from the garden and would be sheltered from a northerly blow. The mount would have to be non penetrating as i dont fancy repairing leaks in a very expensive asphalt roof
my question to you kind people is that can anyone recommend a mount at reasonable price and what size, as i dont want to go over the top as i have to keep the weight to a minimum (self defeating I know).
thanks in advance
MOGG
thanks in advance
MOGG
