none of my nagravision channels work....why?
ash213
DM800HD, INVERTO Silver Tech Universal Twin LNB 0.2, Technomate 80cm mesh dish
BRISTOL
got a 5400 box and none work..
which file should i upload to the box ?
cheers
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
As far as I know the only major provider that is open is digitv on Thor 1 west. All the rest is dark
ash213
BRISTOL
has something happened over the past month or so on 1w?
on nagravision i had about 60 channels or so working...now all black...:eek:
eddik
satellite on astra 19.2
fixed dish,technosat d
digit mf4-s reciever
technomate 5400 usb
sat on 1w
diablo,trex and various cards
north east
got all channels open today just before kick off with new key for diablo cam and then did a blind search and they opened
Yup - Digi TV knocked the auto update out over Christmas. :D
You can still open the channels but you have to put the keys in manually - sometimes. several times a day
Mickha
North West
There is supposed to be a new patch for Technomate receivers with Digi TV AU again, but I can't confirm if it works.
satelliteman
I can, lol :)
you need to manually change the keys or by loading the latest softcam works.
planetx
many reception systems
europe
yes they are OK now!!:)
nunonuk
Neotion 601
Portugal
where are the keys, i cannot find them...!!!
You wont get them here - keys are STRICTLY forbidden. Have a look at The Big List on the main index - theres loads of sites listed.
