pinocchio
- Sep 30, 2008
- Age
- 65
- Mythtv assorted configs
- Kent
Hi All
I have a fully working Mythtv based system that includes both DVB-T and DVB-S elements in the UK.
The system works well and I am now thinking about incorporating Sky into it using a legit Sky card and an NDS Softcam/EMU.
I've read fairly extensively and there's seems to be two ways I could progress.
1. Get a CI and a CAM that supports NDS (Dragon/T-Rex?) that will work under Linux (The Hauppauge WINTV-CI USB seems a candidate). However this means adding a lot of hardware and also having to buy a CAS3+ programmer to program the CAM with any required updates.
2. Buy a programmer (say an Infinity US and using an EMU such as CCcam or GCCam? decode the signals that way. Doesn't require a physical CAM or a CI so saves money.
If i've understood correctly as well if I use something like SASC-NG with an EMU I could in theory decode more then two channels at once (limited by the number of DVB-S cards I have - Has anyone tried to see what the limit of channels is?). Also would the same solution allow me to use a legit Setanta card on the DVB-T side?
Thanks for reading and any help, guidance or pointers would be appreciated.
AN
AN
