Octo LNB (Multiswitch Quad compatible)
healeydave
IT: 1 x iMax 27" Quad Core, 2 x iMac 24" (running OSX & OSX Server) 1 x Macbook Air
AV: MacMini Plex Media Centre, SpearNZB Episode Downloader, DM500, DM8000
uk
Ok, due to my houses existing wiring, I need 6 LNB outputs but not all can be supplied by a Multi-Switch!
If I can still find a source of the Multi-Switches that work off a Quad LNB's (not a Quattro's), would the following work:
Parts to Buy:
1 x Multi-Switch (Quad Compatible) 4 Sat Inputs , 1 Ariel Input, 8 Sat/Ariel Outputs.
1 x Octo LNB (8 independent outputs)
10 Meters of 4 Core Colour Coded Sat Cable
10 Meters of 2 Core Sat Cable
Set-up:
Connect 4 (out of 8) LNB ports to the Multi-Switch
Connect existing Ariel to Multi-Switch
Connect 2 more of the Octo LNB ports direct to an independent room.
I guess all I need to know is if the Quad compatible Multi-Switches will work equally as well with an Octo LNB (obviously only using 4 of the outputs), I can't see any reason why not to be honest.
satelliteman
Vision and Spaun produced switches that were quad LNB compatible, not sure if you can still get them.
The options are either a Quattro and switch or an Octo LNb, both should give the same end result.
healeydave
uk
So if I can't get a switch that will work of a Quad or Octo LNB, I will have to get a Quattro LNB (to work off the regular switches) and a Quad LNB on an arm?
satelliteman
An Octo LNb should be ok for your set up or go the Quattro/switch route which could give you more than 8 feeds, depending on switch :)
healeydave
uk
I can't go one or the other, I need to do a combination.
The reason being, I have existing cabling running in two different parts of the house.
One part of the house requiring me to use a switch to pass both Ariel & Sat feeds to certain rooms.
In the other part of the house, I just need two lnb inputs for a sat pvr.
So my original plan would use 6 of 8 port's on the octo.
If the Octo won't work with a switch, I will have to get two lnbs (a quattro & a quad), the quattro to give me 4 compatible ports for the switch-end of the house and the quad to pull off the two standard ports for the pvr.
Hope I've explained the situation better :-)
Because of the extra losses in a multiswitch it's usually recommended to go up a size in satellite dish - could this be a problem for you?
healeydave
uk
I don't have a problem yet, I am planning an update to my system and checking if its going to work.
You getting me worried now, losses was not a consideration.
I thought if a short run from the LNB to the Switch inputs was done, the switch (if decent) should manage the signal quality is as good as originally received for the on-going outputs :-(
satelliteman
Factors depend on number of multi-switch outlets, mains or receiver powered, manufacture of switch etc.
Which is why, just in case, a larger dish is usually fitted!
satelliteman
Yep 60cm minimum for multi-switch system should do :)
satelliteman
Think the vision 508A with Q2 in the link above has been replaced with the 508S (quattro only).
