stefmeister2005
- Nov 28, 2005
- Age
- 42
- Reciever
- UK
I have a Skystar 2 PCI card that I've been using to pick up 19.2e for the past 2 1/2 years, I now wish to use it to get the Sky Satellite at 28e using my Sky Digital Minidish.
Weird thing is that when I hook my SS2 upto my Sky Dish I get no signal, however when I plus the Dish into my Sky Reciever or Technomate 5200D Reciever using the same cable the signal is perfect. Also If I setup my 80cm Dish indoor's & align it to 28e & plug my SS2 into that I get a good signal, although some channels are missing due to the dish been indoors.
I have plugged my SS into the Sky Dish before & its worked OK, only difference now is that my Pc has Vista installed rather than XP.
Its odd how it all works perfectly on one dish but not on another?
Anyone got any ideas on possible solutions?
BTW I've tried using all the major software, Alt-DVB, ProgDVB, DVB Viewer Pro & DVB Dream & I have the same problem on all of them.
