adam watson
- Jul 4, 2007
- Age
- 42
- 80cm dish, quattrro and m/s for 28.2, singles for 19.2 and 23.5. Sky HD and Fortec Star Passion HD
- Berkshire, UK
I live in a block with about 20 flats, most have a single feed for sky. We want sky plus so require 2 feeds but have been told that there aren't enough feeds for us to have a second. Also we can't have another dish so what are our options? I assume we have a multiswitch, can we buy another and add that or do we need to buy a bigger switch than there is currently, if there are x amount of switches already we need to replace a switch with a bigger one etc.
When we had our sky "installed" (paid £85 to have a wall plate changed...) the guy said upgrading the multiswitch would "cost loads" so am after a bit more info
Many thanks
Adam
Many thanks
Adam
