Welcome to the forum Fireboy
I have moved your post to its own thread please try to remember to start a new thread when asking a new question.
Sorry never heard of that stb however if you had used the search forum button you would have found a post that suggests it may be a clone of a Truman stb, thus if you can find the code for that it may be the same, but why do you want it, that will only reset it back to manufacturers settings?
If the unit has had a patch applied to it then go to where you obtained the patch and ask there for the menu access code if that is actually what you require
