Optimal konfiguration 4 rooms + 4 satellite positions
kiklop07
who
I am
What is optimal konfiguration for 4 rooms + 4 satellite positions?
I know these:
"1 x antenna
4 x receivers
(DiSEqC 1.0)
4 x Uni Quad LNB
4 x 4/1 DiSEqC"
"1 x antenna
4 x receivers
(DiSEqC 1.0)
4 x Uni Quattro LNB
2 x 9/4 multi switch
4 x 2/1 DiSEqC (option)"
"1 x antenna
4 x receivers
(DiSEqC 1.0)
4 x Uni Quattro LNB
1 x 17/4 multi switch"
I think the best is last, can you write another. Can I use "Uni Single LNB" with another "multi switch"? Thank you!
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
It depends on what you mean my 'optimal' ?
Optimal in terms of cost and ease of replacement if a component fails is option 1. The 17 input multiswitches are fairly expensive. The cabling would be fairly simple too I think, if you put the Diseqc1.0 4x1's outside.
kiklop07
who
I am
Optimal - I mean the best. Cable are long distancies in the house, and need good Field Intensity(power).
