Os mini 4k Edision issues
AtOM13
near Marseille
Sedea 80 cm, 1w 13e 19.2e Inverto IBU lnb
Channel Master 1.2m Diavolo lnb (Rimantized, motorized and "nested" at 5m from the floor)
Laminas 150cm
Channel Master 1.8m
Marseille
Hi !
I noticed some issues on my new Os mini 4k:
- impossible to set at 2160 resolution with my TCL TV , only 1080
- transponders with a low SNR aren't viewable while searching ( not a beep )
- can't scan T2-MI mux on 4.8e
Some else got these issues ?
sophie101
* Currently
1 x off set 60cm for 28.2e
1 x 60cm for 5w + 13e + 19.2e
Quad LNBs on each sent to different receivers in different flats.
belgium
Hi !
Hi, I have got OpenVix installed . I tried to play/watch but the 2160 channels never displayed. Just got a black screen.
I have not got 4.8e so cannot test.
If TPs with low SNR did not come in, then I presumed incorrectly that my settings or the information I got the details from was out of date/incorrect and would have moved on. I guess I was wrong!
My dishes are all disconnected because the roof is being repaired. Cannot test now anyway.
The Astra 1 satellite has some UHD test channels (10944/12344 H)
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Can you explain more?
stel883_
Vátika, Greece
Is it hardware or software related?
AtOM13
near Marseille
Laminas 150cm
Channel Master 1.8m
Marseille
Yes, for example when I'm searching a frequency with my Vu+ Duo, if I cannot locked that frequency I can see SNR gauge moving even if it's very low sometimes it's just little moves.
But with the OS mini 4k, for the same frequency I see nothing.
About 4.8e T2-MI mux, when I scan 11747 V (with PLP 0 and PID 4096 ) I received all channels of this transponder except T2-MI mux
EnoSat
enosat.euweb.cz
Slovakia
Encoded T2MI will not scan any e2-box (only receivers with modified driver for T2MI support scan FTA T2MI pid), no one has modified the driver for e2 yet :(
In e2 you can only use Astra-SM for encoded T2MI pid.
stephan94
Bavaria
Hello ,
For the T2MI mux on 4.8° East you can't get it because it's encrypted so the receiver doesn't take it into account. All Eningma2 receivers have this problem.
The only receiver I know that can receive the two T2MI of the 11747 V is the openbox.
enosat was faster than me
stephan94
Bavaria
Here you can read that on the OSmio4K only the TNAP 5.0 image allows you to see the transponder signal, even when the SNR is not sufficient (I don't know if this image is available for OSmini 4K).
hatters1976
Wave frontier T90, Dish 2.40. Edision os mini 4k, Octagon SF8008 SUPREME, GT GOMBO, GT MEDIA V8X, HOMATICS 4K PLUS ANDROID TV BOX.
GR
In 7 east i can confim feed that is not locking on octagon supreme is ok in edision os mini 4k with signal 9.5db-10.1db
Forgot to mention, if the receiver can accept apps then whilst your dish is offline, look on YouTube for something in 4k.
AtOM13
near Marseille
Laminas 150cm
Channel Master 1.8m
Marseille
Salut Stephan,
Yes image is available but it impossible to register on official forum to download and test it:(
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
With Edision OS mini 4K I receive the T2-MI channels from 16°E
AtOM13
near Marseille
Laminas 150cm
Channel Master 1.8m
Marseille
T2-MI ok on 16e
2160p resolution ok too (TV setting )
Low frequencies like 10492 mhz ok too but no frequencies with low SR
Now I'm looking for a TNAP 5.1 image to flash it on USB directly ( no multiboot)
hatters1976
GR
There is a sigificant difference in db measurement in edision os mini with other receivers for example
octagon supreme. Can we find a way to confirm which of the two receivers singal testing is more for
accurate results? Also in blind test edision os mini gives only the transponders that you have actually
signal. In octagon supreme gives all available transponders ...
AtOM13
near Marseille
Laminas 150cm
Channel Master 1.8m
Marseille
So after flashing with TNAP5.1 all is ok:
- low SR transponders ( 400 seems to be the limit )
- signal gauge is very accurate even with low transponders not locked
I have to add services using "Dreambox edit" when transponder is lock but no channel tv or radio appears when scanning, especially for low SR
You could order a spectrum analyser that has been calibrated against known reference inputs.
ArloG
12' Fiberglass Dish, C2W & Geosat Pro lnbf, Titanium ASC-1, Osmio4k, Zgemma H7 Client
N. Central PA, USA
There is a snippet of info that the "next" incantation of the SF8008 will address low SR tp's.
So it looks like a hardware limitation.
And BTW. You can take those tnap mini, mio4k drivers and plug them into ViX just fine.
