Paksat 1R 38E
hi Nelson tried this bird last night cannot get AJK but got Jalwa on 3824V with good strenth.
hi -
i,m not certain that AJK transmits in the evening -- it seems to cut off abruptly around 6.p.m. for me ? -- have a try during the day/afternoon . (i,m away from home at the moment so can,t check it for strength )
cheers --
thanks for that nelson will try in daytime.cheers
hi - just had a look here 1.45 p.m.
i,m receiving "A.J.K." and "Jalwa " -- A.J.K. is weaker but is holding a constant lock. ROHI PK on 4098 V 3255 is showing some sign of life but will not lock .
cheers --
thanks for that nelson i will also try ROHI PK,i will let you know how i will get on.
hi -
this one just popped up on a blind scan
3973 V 6509 - 3 channels - KTN mux
cheers nelson.b.
hi nelson tried paksat just now all i got was Jalwa at 54% quality and Dunya TV Int on 4133V 2222 at 58% quality but scrambled,KTN mux no go only 42% not quite there,you are doing well on this sat.
nelson_b said:
hi -
first time also for me .
hi -
my blind scan must have missed - Dunya TV Int 4133V 2222
i put it in manually and its stronger than "jalwa" here for me.
KTN mux is still ok here tonight.
there is no pattern to the channels that i receive from this sat -- here today - gone tomorrow
the only constant for the last month or so has been "jalwa"
its a clear night here - maybe i will try to input some other t.p,s manually - the blind scan seems to sometimes miss the low symbol rate ones .
cheers --
hi -
some changes here for me recently -- Jalwa 3825 V 2799 is no longer receivable here - no signal at all (maybe ceased transmission)
AJK 3785 V 2799 still ok during the day 1.00 - 5.00 pm
and two channels have re-appeared on wednesday night that i,v not seen for nearly 1 year ---
8XM and Apna news on 3960 V 7234 --- still receiving them tonight despite awfull weather
hi nelson tried this evening AJK came in at 57% quality and 8MX and Abb Takk came in at 50% quality Rohi showing 44% quality no lock
hi -
may have had this channel before in the distant past ?
anyway its popped up tonight on a blind scan so here,s a pic
Sindh News - 3739 V 4340
hi nelson its a strange bird, if I do a scan sometimes I get nothing or the only channel that scans in is AJK all other channels I have to manually put the frequency and symbol rate in or put both the frequency and symbol rate and pids in.
hi " pride"
it,s certainly a strange one -- blind scan with the F15 works quite well on this sat -- on some other sats not so well !
AJK is a constant now through the afternoon --
the new channels that i,v been getting since just before xmas are still being received here - but only in the evenings -- they are too weak to lock in the morning and afternoon
regards nelson.b.
A strange bird indeed ...in that for me it rarely exists ..
I point Christina at it ...or at least where I think it is ..and get Nothing..
Sometimes occasional hints of AJK ...but mostly a dead spot in the arc.
C @ 38deg x 2.2m =
ATV Pakistan putting in a good signal this morning on 4081V.
hi aceb thanks for that getting it at the mo at 5.6db
by the way paul are you getting metro 1 news on 3782V I am also getting that at 7.1db
Nothing at all from that, is it full time as I know AJK goes off air around 1700. Getting Apna 3966V @ 5.6dB.
hi paul its still there the signal has increased to 7.5db I will try apna on 3966V
