Panasonic tu-dsb50 digibox retuning
vento
panasonic tu-dsb50
ireland
I am using this box for freeviewing channels but put in an old sky card which has now erased/moved the freeview channels being received(e.g. channel 101 was BBC1,102 was BBC2,103 was ITV).How can I reset/retune the digibox to return to viewing the freeview channels I had before trying to use the old sky card?:confused .
satelliteman
Try a forced update. Unplug the receiver, power it back up whilst holding the back up button. These channels should be listed on the EPG without the use of a viewing card, except the ftv channels, Five & family, Ch4+1 and Sky 3.
You shouldn't need to do a forced software update, just taking the card out and disconnecting/reconnecting the digibox at the mains should restore what you had originally. What were you hoping to achieve with the old card?
vento
panasonic tu-dsb50
ireland
Removing card and disconnecting/ reconnecting power to digibox has worked perfectly and restored the original channels. I was trying to see if I could get extra Irish channels too(RTE 1, RTE 2, TV 3 and TG 4 0 but will do without them rather than subscribing to Sky.
Thanks to alll for such prompt assistance
The RTE channels are pay services and are not available without a subscription.
Eamon
Freeview
N.Ireland
Am I correct in thinking that RTE is available free in the Republic of Ireland if you have a Sky dish. As I live in Northern Irleand and was looking to get the RTE channels digitally but was advised one way of doing was to get a dish and/or card in the Republic and bring up North. Although i may have to pay Sky subscriptions for the minimum period I could live with that. Can anyone advise me if this is correct
