password protect channels on Dansat receiver
Dr.future
Dansat,DSR-7500
KSA
how are you?
Thank you for your help ...
well, i have problem with setting a password for channels that are not suitable to be viewed for children...so, I have DANSAT receiver, DSR-7500 type. I know how to put a password for menu from parent lock but Can anyone of you help me to make a password for any channel that is not appropriate for children rather than deleting it ?I'll be thankful to him/her.
your brother
Dr.future
kind regards
I have changed the thread title to something useful. When posting please try to use meaningful titles - you wont get any help from the people who have an answer if you dont get the titles right!
Dr.future
Dansat,DSR-7500
KSA
well, i am sorry brother for that...but i really need help ....
and thank you so much for changing the title ...
waiting your help
best regards
To be honest Id be very surprised if you can password protect individual channels.
Either password the entire receiver and deny the kids the ability to use it at all without supervision
or
Delete the stuff you consider unsuitable. Then password protect the setup menu.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Yes, it is possible to password/PIN protect individual channels on some receivers. Mine does. I just go to a channel edit menu, and press OK, to LOCK each channel that I want to protect. I don't have the foggiest obviously, how to do it on Dr.future's receiver though.
