Penta for 1.02?
Albert
After reading "Penta 1.11 released by Ushtar" I am unsure what is the recommended version for MM 1.02?
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
1.09 will be ok for 6 in 1 use but for Connax a special 1.11 is required. I believe that will also be ok on 1.02. Is it an official cam Albert?
Albert
There is no need for Connax. MM should be used only with an official ORF-card (Austrian TV). At the moment the MM has penta 1.05 and it doesn't work anymore. Before the card was used with a Humax BTCI 5900, which has the cam onboard. So a file with md5sum c13b694b652679bd591a7c504124a9b2 should be ok?
Albert
Is there a newer version than 1.09 available in the meantime now?
