PHEONIX APOLLO CI Software Problem
andyw37
SkysNotTheLimit
Tring 90cm & Viasat
Moscow
I am trying to load the software to the above receiver.
When switching on receiver to start the download I get the message ' Wrong Format File'.
Thought this may be the length of file name but is not.
Anyone canme across this?:-doh2
I'm assuming that you are using the correct file version, correct for your model?
andyw37
SkysNotTheLimit
Tring 90cm & Viasat
Moscow
Yes, have used from Pheonix site, have no problems with TM & Octagon??
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Look I know this may appear to be a dumb ass thing to ask but I have known people forget to unzip and extract the file before trying to load it
andyw37
SkysNotTheLimit
Tring 90cm & Viasat
Moscow
Yes have unzipped, works sometimes then stops at about 59% of transfr.
Topper
But I thought you were getting wrong format message?
andyw37
SkysNotTheLimit
Tring 90cm & Viasat
Moscow
Yes getting it from outset, then try again 59% then stops.
Will try another rx tomorrow.
Topper
I would have another look at the website you obtained you firmware from as some stb's like to have the flash rom completely erased before upgrading
kip
I am not a number
Eagle Linux
south east uk
What software are you trying to load? What loader are you using? Have you loaded anything onto this reciever before ok? I havnt had a prob with mine before but might be able to help with software updates - I notice you have the ci model - your not trying to download ci mc update are you .. This might cause a problem??
andyw37
SkysNotTheLimit
Tring 90cm & Viasat
Moscow
Thanks,
I am using SW off www.phoenixsat.com and eurosat state that it is the latest version.
Yes i am using the CI SW, so who knows !!
Why not try one of the versions from alsat, they look to be more up to date.
costa10
n/a
London
chanche software to open box
NormanBanks
Octagon 318 standard computer
Cyprus
Did you ever get it going as I have same problem and would be grateful if you could post what you did please
