gumboe
- May 31, 2005
- Age
- 45
- Standard Sky setup with Thomson DSI4101
I recently bought a Philex 'screened twin coax outlet with sat outlet' wallplate from Maplin. My question is (as there are no instructions with the wallplate) how do I connect this up?
I've got a sky engineer installed minidish with a single LNB, I plan to put up a terrestial tv and a separate FM aerial up soon. I live in a poor reception area so I'll probably need something the size of a kids climbing frame on the roof.
As far as I know - I will need 3 coax cables coming down from the roof to the area behind the tv. This is why I've got myself the Philex wallplate, because I think this is what I need so that I've got easy access connections on the wall for FM / TV / SAT.
How do I cable this wallplate up? Inside the wallplate there only appears to be 2 places I can screw down some coax and these aren't labelled. Shouldn't there be 3 coax holes on the back of the wallplate.
Is there a better way to be doing all this?
Thanks for any help you can give.
