Plasma
bim
lat 45.3301 lon 14.1822
humax foxsat Thomson Tsr200 Pace 3100 Black pro quad dvbs2 80 and 100cm dishes
croatia Lat 45.3301 Lon 14.1822
I hope this is the right section. I have noticed recently on our plasma TV sort of smokey smears behind the screen. It can only be seen when the picture has a light background ie white/blue colouring. Is there any way of cleaning this ie air blast it out through vents if it is dust. Now I have noticed it , it is becoming a pain as I keep looking at it and not what is on TV. Any help will be appreciated.
bim
Thanks CH, I will take a pic later weather too good at the moment to be inside (makes a change!!)
bim
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Does the plasma use fans internally ..some models do ?
Does anyone in the house smoke ?
I have had cloudy patches on plasma screens before ..where the internal fans have drawn cig fumes and or other substances from cooking etc into to the layer between the front layer of protective glass and the plasma screens glass ..
The only way to fix was to seperate the two layers and clean ..
A 2 man job minimum ..
Not always 100% effective ..
plus you run risks like ..cracking the screen (very heavy) ...and damaging the thin polarising chemical layer often on the inside of the glass ..
resulting in streaks which if not done correctly looks worse than the original patches.
rgds
VS
Clown man
28,2 & 19,2 on Gibby 150cm ..2x Opticum Premium LNB's....Opticum 5x12 Multiswitch....Humax Freesat HDR's custom FW ...Pioneer Kuro & Panasonic Viera W60 Plasma tv's
Munich.....Germany......
If its a magnificent / fantastic Pioneer Kuro Plasma..? ...........Viperscan's great advice won't work.......as Pioneer use a special bonded Plasma screen.....
If its a Panasonic plasma ......it will be worth having a go at repairing/ cleaning.........
If its a cheap rubbish / crap Tv from LG....or ....Samsung .......don't bother........chuck it in the bin..............Spend a bit more money next time ........And get a good Plasma Tv............
2cvbloke
Near Pontop Pike, Co. Durham
You need to rebalance the dilithium matrix to get a stable matter/anti-matter reaction to form a pure plasma flow, oh, wait, that's warp plasma, not telly plasma... :-doh
bim
rgds
VS
That sounds exactly what it is. No smoking in the house but we used to have a really big traditional bonfire fire place which on occasion did smoke a bit. Come to think of it it appeared in the winter months. I have since removed this and installed a log burner. There is no internal fan that I can hear. It is a philips TV and pretty good for sound and picture although getting a bit old now. I suppose to access inbetween the plasma screen and front screen everything is done through the back as this is where all the screws are. What would you advise cleaning it with. We have screen cleaner for the outside screen or perhaps it may only need dusting off. Must appreciated the info (just remembered how heavy it is!!)
bim
Scotty rang last night, he said beam it up in the morning and Spock will clean it for you!!!!!!!!!!!!!!!!!!!!!!:-rofl2
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I suspect you have your answer ..
Smoke fumes from the fire place ..
between the layers ..
As to cleaning..
NO chemicals or specialised sprays ..
Nothing abrasive..
gentle action only with a sponge and luke warm water and liquid soap is all I used ...
Dusting with a paintbrush and a hoover held inches above the glass surface ..
ALL tiny specs have to be removed before reassembly ...
BUT in truth ..I don't recommend a novice in electronics to attempt this as just about every panel has to be removed ..and the set fully disassembled...
screen panel tabs tear easily so not for kak handed folk ..
Minimum of 2 people to lift the screen ..
Not a job for just anyone .. I advise you not to attempt unless you know what you are doing ..
There ARE risks ..
I never attempted this job even on a 42 inch plasma for less than £150 ...so it gives you an idea of difficulty/risk and complexity.
rgds
VS
bim
Thanks for the insight i am quite handy at most things but I will have to ponder on this as I only have the Mrs here.(I remember putting it up!!!!)
