Please help finding softwear and keys for KONKA
freeman
Konka Satellite TV receiver
Mid East
I have KONKA KSDS810 satellite receiver and I need the keys for channels on 1 HotBird. Please help.
Well you wont find any keys on this forum. You must have read the rules which state No Keys.
We do have a long list of sites that carry keys though - they are in the Big List which can be found on the main index page.
lubag
konka reciever
israel
1. I also have tis konka sat reciever and I need its PDF to know how to config it.
2. I need to know how can i add new satellite, How can I find the transponder for it, search and add the station I found and ect...
3. Moreover, my dish aimed to AMOS1,2. what other satellite I can connect to?
Please help.:confused
HB13DISH
Retired Mod
Middle East - Israel
Hi lubag,
1 - Sorry I haven't heard about this STB. Is it FTA?
Try the internet.
2 - When you find the manual, this should be easy.
3 - If you do a scan, you might also pick the 5W satellite.
You can add Nilesat 7W to it, but you need to change the LNB to one which has a 3 degrees difference like Invacom. Will depend on what type of dish do you have.
You would then need to buy a Showtime smartcard and your STB should have Irdeto support.
If you can add another dish, then go for Hot Bird 13E. See my system.
Or use a motor.
