please help me upgrade one EUROSTAR Eurobox-9700
gsmsikar
hi
please help me upgrade one EUROSTAR Eurobox-9700,
i am unable to upgrade this receiver, i have downloded all the flashing software and file from the eurostar website but as the help file has described there that to connect the receiver with the pc we have to connect a cable using DIRECT CABLE 2 to 2, 3 to 3, 5 to 5., i have made the cable and tried to connect the receiver with my pc but it didnt work , i tried many times but i cant connect , then , i tried to connect my receiver with a NULL MODEM cable , and i was able to connect the receiver with the pc, but the hyper terminal screen does not shows the display as it should show as given in the help file ,
then i think that i should leave it and ask this in the forum ,
and please also tell me how to identify the receiver as which 9700 model it is?
it has
STi5518DVC-X (Micro)
TE28F800 (Flash)
K4S641632E-TC60 (Memory)
please help me
thanks..
bye
gsmsikar
eurostar log with hyper terminal and null modem cable when connected with pc with 9700fta_new software
please help me now
Sector 7FF60000 Erase, Porgram OK
pgm blk=12, bufPtr=40080018
Sector 7FF80000 Erase, Porgram OK
pgm blk=13, bufPtr=400a0018
Sector 7FFA0000 Erase, Porgram OK
pgm blk=14, bufPtr=400c0018
Sector 7FFC0000 Erase, Porgram OK
pgm blk=17, bufPtr=403fbbf8
Sector 7FFF4000 Erase, Porgram OK
Restart...........>>>>>>>>>>
Viacess DVB Boot Ver 1.00a Mar 20 1999 at 15:26:59
CPU - ST20TP3
Flash 2M, DRAM 4M, MPEG SDRAM 2M, C/I, External Modem.
key : 0x3
Jump to Main
Initialising Flash ...
Flash init ..
OnChip flash = 403ffe38 size: 0xc8
Flash init ....... OK!!!
Flash init ..EVAL-STB4 Reference Firmware
Version 1.2 of Oct 17 2000 at 16:37:16
Update -> Oct 17 2000
Initialising I2C ...
=> i2c init ok...
=> pti init ok...
Initialising PWM ...
Clock Recovery/PWM init: OK
Initialising Load Flash ...
Init flash home channel
check sum : 1f74
current NIT version = 0
Initialising OSD ...
*** STB FLASH Version : 9040 ***
*** S/W FLASH Version : 9040 ***
FLASH memory channel(psi) data is OK
Standard TV RGB Off
RF => PAL BG
RF Data : ca88 48 25 f4
884825f4Initialising the Digital Video Encoder
STV0119 Encoder ->PALBG, RGB
ttxt reg[34]=0x00, reg[35]=0x00, reg[38]=0x00, reg[45]=0x00
STV0119 Encoder configured
Initialising the STi3520A
Initialising 3520 Loop 0
Initialising PLL
Done !.
3520A initialised for ES decode only
3520A initialised for full PES decode
STi3520 V
STi3520 A
>>>>>>>>>>>>>>>>>>>>Initialising the 3520A C Version.
Setting up the mpeg video interrupt
Setting up the mpeg audio interrupt
Start mpeg audio packet management process
Starting the mpeg iic traffic management process
Starting the mpeg audio sync play start process
=> mpeg init ok...
Initialising the gprim library
Testing block move engine
=> gprim init ok...
ver=0,sn=0
Initialising Ttxt ...
Teletext driver library v1.0 - Version of Oct 17 2000 at 12:17:14
Initialising TABLE .................
'teletext_handlThe 'teletext_data_transfer' task is running
er' task is running
PAT PROCESS CREATE OK.....
PAT process started
PMT PROCESS CREATE OK.....
PMT process started
table buffer : 0x40058c00 size : 2048
SDT PROCESS CREATE OK.....
SDT process started
table buffer : 0x40057bf0 size : 4096
NIT PROCESS CREATE OK.....
NIT process started
table buffer : 0x40056bd0 size : 4096
CAT PROCESS CREATE OK.....
CAT process started
table buffer : 0x400563c0 size : 2048
B_PMT PROCESS CREATE OK.....
Background PMT task start
table buffer : 0x400553a0 size : 4096
B_CAT PROCESS CREATE OK.....
Background CAT task start
table buffer : 0x40054390 size : 4096
=> TABLE init ok...
table buffer : 0x40053370 size : 4096
Initialising TUNER .................
I2C front init ok.
disable back PMT
disable back CAT
Global Front I2C Reset
Tuner Init Start
Lsi 64724 sync byte ok!
LSI64724 init ok.
Tuner Init Process ok
LSI Tuner Process Created
DisEqC process start ok
DiSEqC Process ok
Change TR 0 = 1358.0MHz
=> TUNER init ok...
LNB_H/W On
LNB on
Initialising Front IR ...
Initialized KEY SCAN & Display Process!
Start 7-seg Display Process!
Initialized IR handler!
=> front_ir init ok...
smart card driver memory allocation Success
smart card driver memory allocation1 Success
card 1 is null!!
service_process_params is OK!!
smart card driver memory allocation3 Success
Service Process is initialized
ASC interrupt is initialized
ASC interrupt is initialized confirm
smart card detect interrupt is initialized
Initialising Viaccess ...
TABLE VERSION PROCESS CREATE OK
table version monitor started !!!
Ok to create smart card process
smart card detect monitor task started...
smart card init monitor task started...
smart card i/o monitor task started...
pi_program_client_register was called => OK
Viaccess version 100.v412 compiled on Aug 11 1999:18:04:31
VIACCESS init OK !!!
recover
22k Off
hor
Fi:1025 Fd:0 Si:28 Sd:0 V:4
Change_Frequency=>TS:1
PTI_PAUSE
^^^ tr:1 sat:2.0 ^^^
Reset LNB offset(0)= -500 KHz
Initialising CI ...
DVB Common Interface Version : 1.00.03 JULY/25/2000
Current H/W, S/W, Compile mode.
CAM VCC/VPP control.
CPU ST20TP3.
CAM interface : SAMSUNG PALCE22V10H.
1 SLOT.
Ci task create ok
CI process start!>>>>>>>>>>>
Ci timer task create ok
Ci Link layer task create ok
=> CI init ok...
Initialising TASK ...
ver
Ok to create My_ch_change process...
My_ch_change process: Started
Ok to create My_downloadAll process
My_download All process: Started
Ok to create TDT process
TDT process started
Ok to create EIT task ...
start DVB EIT download task ...
EIT process started
table buffer : 0x40050aa0 size : 2048
ForcePowerOff()
DVB EIT structure size 228
table buffer : 0x4004fa60 size : 4096
=> SLOT[46] was flushed
======== SLOT DEALLOCATION =========
max event is 2047
=> SLOT[45] was flushed
Waiting EIT packet ...
EIT aborted
disable EIT
EIT stoped ok
disable TDT
TDT stoped ok
PTI_PAUSE(SLOT OFF)
=> viaccess deactivated
OSD> POWER_FAILURE_PROG_FLASH
Compare RAM & FLASH -> Same!!!
LNB off
ver
22KHz Off
PAL_NTSC.... process start....
Initialising user i/f =>
start DBS_usif_task ...
usif process created successfully
*** Eurostar logo on....USER I/F OK
Eurostar CI DVB ver 1.10 Jan 12 1999 at 03:00:42
Ram Clear
Check Sum EA26 OK
Start add=0x7FF3AE58, End add=0x7FFDFFFF
Start sector = 9, End sector = 14
Valid Sector. So write Magic
pgm blk=17
pgm blk=9
Sector 7FF20000 Erase, Porgram OK
pgm blk=10
Sector 7FF40000 Erase, Porgram OK
pgm blk=11
pgm blk=12
pgm blk=13
pgm blk=14
pgm blk=17
Exist SW
AMD FLASH Found!!!
FLASH Init OK!!!
anon flash32.c 387> Flash init ..
EVAL-STB2 Reference Firmware
anon pwm.c 140> Clock recovery/PWM init
Version 1.2 of Aug 10 2000 at 14:29:57
update -> Aug 10 2000 14:29:57, 20
Initialising Demux ...
anon demux.c 1864> demux_init: Demux Aug 10 2000 14:26:48 ST20TP2.
anon demux.c 2086> demux_init: Internal memory high = 6736
anon demux.c 2092> demux_init: OK
check sum : 4251
*** STB FLASH Version : 8060 ***
*** S/W FLASH Version : 8060 ***
Standard TV RGB Off
RF => PAL BG
884825f4
Initialising ST20 Sytem Layer ...
anon mpeginit.c 287> Initialising the Digital Video Encoder
anon iicvideo.c 135> STV0119 Encoder ->PALBG, RGB
anon iicvideo.c 194> STV0119 Encoder configured
anon mpeginit.c 290> Initialising the STi3520A
anon mpeginit.c 1614> Initialising 3520 Loop 0
anon mpeginit.c 143> Initialising PLL
Done !.
anon mpeginit.c 1116> 3520A initialised for ES decode only
anon mpeginit.c 1152> 3520A initialised for full PES decode
anon mpeginit.c 295> STi3520 V
anon mpeginit.c 297> STi3520 A
anon mpeginit.c 370> Setting up the mpeg video interrupt
anon mpeginit.c 373> Setting up the mpeg audio interrupt
anon mpeginit.c 379> Starting the mpeg video packet management process
MpegVideoPacketManager datapipe.c 128> Starting the mpeg audio packet management
process
anon mpeginit.c 397> Starting the mpeg audio packet management process
MpegAudioPacketManager datapipe.c 187> Audio packet consumer process: Started
anon mpeginit.c 415> Audio packet consumer process: Started
anon mpeginit.c 431> Starting the mpeg audio sync play start process
Initialising Gprim ...
anon gprim.c 52> Initialising the gprim library
anon gprim.c 55> Testing block move engine
ver=0,sn=0
TV/RGB off
Power LED off
anon front_ir.c 1345> Initialized KEY SCAN & Display Process!
anon front_ir.c 1351> Initialized IR handler!
LNB_H/W On
Initialising SFILTER ...
section_init: OK
demux_make_circulist ok
demux_set_buffer ok
anon qpsk724.c 1159> Global Front I2C Reset
anon qpsk724.c 1180> Tuner Init Start
LSI64724 init ok.
Tuner Init Process okated
DiSEqC Process ok
DiSEqC Process ok
00[KHz]
Change TR 0 = 950000[KHz]
Initialising Private ...
anon ttxt.c 180> Setting up Teletext Interface interrupt
anon ttxt.c 189> Starting the Teletext Driver process
Initialising USIF ...
anon ttxt.c 200> Starting the Teletext Send process
*** Eurostar logo on....*** Eurostar logo on....*** Eurostar logo on....TTXT Odd
enable
!!!! Fs : 90MHz !!!! Ts : 58mSec 2
micro code download start...
micro code download complete!!
!!!! Fs : 90MHz !!!! Ts : 56mSec 2
Chan data status : BOTH_CHAN
QPSK_Change_Channel start
=>F:973 S:29 V:4
22k Off
12V Off
hor
OP_Mode : 0
Orbit_pos : 2
Repeat : 170
High_Low : 0
Polarity : 0
ver
Switching On DiSEqC
hor
Change_Frequency=>TS:0
!!!First!!! channel_index 0, actual_channel 1
actual_prog_index 0, AV_Chan_Flag 1
^^^ tr:0 sat:2.0 ^^^
Change Freq(1) = 973000 [KHz]
Reset LNB offset(0)= -901 KHz
actual = 972099 [KHz] !!!! Fs : 90MHz !!!! Ts : 53mSec 2
OP_Mode : 0
Orbit_pos : 2
Repeat : 170
High_Low : 0
Polarity : 0
ver
Switching On DiSEqC
hor
Change Acq(2) = 973000 [KHz]
OP_Mode : 0
Orbit_pos : 2
Repeat : 170
High_Low : 0
Polarity : 0
ver
Switching On DiSEqC
hor
Change Acq(2) = 976000 [KHz]
OP_Mode : 0
Orbit_pos : 2
Repeat : 170
High_Low : 0
Polarity : 0
ver
Switching On DiSEqC
hor
Change Acq(2) = 970000 [KHz]
OP_Mode : 0
Orbit_pos : 2
Repeat : 170
High_Low : 0
Polarity : 0
ver
Switching On DiSEqC
hor
Lock Fail, but Init CI!!!!!!
Common Interface Version : 1.00.02 OCT/01/1999
TSI_bypass()
CI_defualt_state()
Created CI Timer_Process!
Start CI Timer Process!
TSI_bypass()
TSI_bypass()
CI_defualt_state()
cess!
Created CI_link_Process!
ver
Change Acq(2) = 979000 [KHz]
Switching On DiSEqC
start DVB EIT Parsing
my_check_active process: Started
max event is 2015
ite mode
Set TV 4:3 Composite mode
CH NO: 1, EWTN prg id 0x11f9
=>F:973 S:29 V:4
22k Off
12V Off
hor
same Diseqc control in channel change , so just jump by ljch
actual = 972099 [KHz] act_prog_idx : 0
check card ok
PGM P=03e9 V=03e9 A=04b1
Set Teletext data 44d
RF => PAL BG
884825f4Power LED on
Created pal_ntsc monitor process.
root_process main.c 745> No errors during initialisation
Created trap monitor process.
STTBX_Init()=Ok
STAVMEM_Init()=Ok
STAVMEM_CreatePartition()=Ok
STEVT_Init()=Ok
STI2C_Init()=Ok
PTI_Init()=Ok
STE2P_Init=Ok
STflash_Init=Ok
STFlash_Open Ok
Ok
Success for write protection
STE2P_Open=Ok
FRT_Init() = OK
Favorite [0][0] = 0
Favorite [1][0] = 0
Favorite [2][0] = 0
Favorite [3][0] = 0
Favorite [0][1] = 0
Favorite [1][1] = 0
Favorite [2][1] = 0
Favorite [3][1] = 0
Favorite [0][0] = 0
Favorite [0][1] = 0
Power On Mode = LAST CHANNEL
mCURSat = 0
*** BOOT-UP After Noraml Power Off [LOGO/INFO]***
STAUD_Init(AUD)=Ok
STDENC_Init(DENC0, InvOut 1)=Ok
STVTG_Init(VTG0)=Ok
STVID_Init(VID0)=Ok
TextFontInit=Ok
STAUD_Open(AUD)=Ok
STDENC_Open(DENC0)=Ok
STVTG_Open(VTG0)=Ok
STDENC_EnableVideo()=Ok
Encoder_Init(0)
STVID_Open(VID0)=Ok
Eit Init = EIT Slot[1]
OK
============Normal Board[v1.2 Sep 23 2002]====================
Chip STi5518 in board MB275 64MB
CPU Clock Speed = 81000000
cjavak
I have a technosat 6000plus digital satellie receiver.I done it upgrade but this receiver not open the all scambled channen.If any have a experence for open the all channel with technosat .Please send me detail.
my email: cjavak@yahoo.com
kh200476
Iran
Hi every body
how can i inter new codes to my receiver manualy,i need password(key codes) to inter table codes.my reciver model is eurostar 9700f
rastiya
Rastiya
from srilanka
asiasat3s
gsmsiker can you please tell me,i have eurobox7300 without cam and if i be able to download the new vertion of the software from the given site and able to conex or other type of decryption facility to be activated.or do i need to have the CI slots for that perpose.
kh900s
my love to lazio
starsat sr X 3500 cuci ultra
pc contain motherboard ASUS free pentiume 4 (2400 MHZ)
north africa
hi all
i want know how i can upgrade my reciever to open scramble programs
reciever is eurostar 9700 plus euro box
thanks
sunukumar
sunu
UAE
kh200476 said:
Hi every body
Hi all
I want know how I can upgrade my receiver to open scramble programs
receiver is Eurostar 9700 Plus Euro box. Please let me know the procedure to enter the code. My e mail sunukumar*gmail.com
