tinux
- Jul 26, 2007
- Age
- 60
1.2m with H2H motor
Technomate
Surrended with very high trees from 30E to 90 W and only able to watch hotbird
- London
Hi guys I need your help please. (my first post)
hello to all of you guys . i used to be an old member back in the time of the old d2Mac
My issue is this
I moved to a block of 6 flats and i am having a problem with sat settings in my own
I have a faceplate with 2 sat connections and an Ariel
Sat1= sky+
Sat2= Hot bird +PLUS SKY+
We are told we can have sky+ plus Hotbird sat or sky+ and sky Hd but not SKY Hd and Hotbird
I have been a sat enthusiast since the old Analogue D2 mac etc.. And have no problem installing any disk but IRS is new to me. So I did a research and found
On the roof there are 2 dishes connected to a Quattro LNB which is connected to a Multi switch 9/5
V/low
V/High
H/low
H/high
Plus Ariel
Now on my Technomate TM-500 If I connect the cable to any outlet I can immediately receive Sky( i understand by that that sky is connected to input one (right ?? no??) in the swich
I have tried all LNB setting and can not receive all channels on hotbird. Sky is always fine
Now if I set 2 satelliteson the menu like these 2 examples
Expel:1 i get all low frequencies channels if
Sky connected to LNB 0 hi/lo volt= v/h
Hotbird connected to LNB1 22khz off volt=v/h
I do not get any high frequencies channels
Expel 2-
Same as above but with hotbird 22khz is on . i lose all low frequency channels
For those who have TM-500 would know that if i were to click on LNB i get 2 menus:
1 –tone either none or A or B
Disecq none or 1.0,1.1 or 1.2
If i choose 1.2 there are committed and uncommitted... (new to me )
I have tried all combinations and in nutshell i can either get low frequencies or high frequencies on sat1 ie Hotbird whe n playing with 22khz on or off
Any idea how I can over come this?
The installers were useless. One simply said that their system support Disecq 2 and i should set my Lnb as high as possible
Many thanks
My issue is this
Sat1= sky+
V/low
V/High
H/low
H/high
Plus Ariel
Expel 2-
Many thanks
