Please Help
uksathees
Guys i know there is a tutorial on the tutroial section that explains this but i fellowed it and it didnt work.
basically i just bought a Elvis multiprogrammer V3.5 serial + a gold wafer card.
i like program it with Pic16F84.hex and Eep24C16 by Neo.hex but it wont do it,
i am using the multiprogrammer 1.9 TJ.
when i wrte these files the porgram says the pic card programmed successfully but every time i put on it smart card reader it says smart card error.
i was reading about programming the pic with a loader inorfer to get acces to the epprom chip on gold card. please advice me on this. i been at for 5 hours now and still no luck.
some please help.
uksathees
hi any Elvis users here?
i did some more reading and got the impression in order to program the eeprom on a gold calrd i have put a loader into pic first, then tranmit eeprom files throuh the pic.
also how do i get the phonix/smarthouse interface to work with elvis?
some one must know hehe, give me helping hand here please.
mhku
TM Nano ~ sg2100
Midlands
can't help with your problem, but do you mean "..in my soul" or is it really in your feet? ;)
Ive always just copied both files over at the same time. Make sure you programme the correct files onto the two parts of the eeprom. Ive always found a lot of the files dont work properly anyway.
uksathees
hi what do u mean by two parts of the epprom, sorry i am new this please bare with me. thankas
Using the s/w that come with it, when you set up a new project you get 2 sections each section normally requires a file - one is the pic file, the other the hex. From memory the pic goes onto the top one.
(Unless you are using the new via 2 flash to clear TPS, in that case you only program,me one section)
uksathees
there is ony pic hex and ee hex, so i am gussing put them in the pic and eeprom memories, seems simple lol but can get a result out of it.
i tried winphonenix to porgram the epprom with a pic loader, it said ok and pgromrd it, but it said the gold card was multimac 2.14 or higer version, i am thinking that is allright or is the card not a gold card.
at the back of the card it saus GWC-001 and 4/02.
uksathees
what is the different between MM2 gold card (multimac 2.14) the one i have, and the gold wafer cards? are these nordic version?
If you are programming a gold card, then just use the standard Multiprog software, what file are you trying to load?
uksathees
GW file from papagen, pic16F84.hex and ee24c16.hex (via_1and_2 for TPS and ART), the card is empty whe i got it, so do i need to anytihnk else that loading these files.
i dunno how right i am but i read that gold card multimac version cant read the hex format, then need the keys in multimac format, what this means i have limited understanding. mabe i have old version of the gold card?
i bought this off ebay.
my reciever is smasung 9500A em via, is not patched, well it cant be i think.
after i load there files, it comes as "CARD ERROR" when i go to the embedded viaccess on the menu and when i tune to TPS channels or anyother viacess ecrypted channels it sais 'please check smart card'
