Please note how the ZENEGA STB Edit function will work.
Vivek
Bandit Queen
Satellite Blood
Dear Friends,
Press Menu button & come to system information, select Software upgrade, press 9009, and now new window open. Come to Factory Data & press ok now wait for a minute and after come back to Installation, select the search setup & press ok, now select the TP & press GREEN Button for Edit or press Yellow Button for ADD. This system will work for only one time.
Cowboy....O-Ha :D
markand
Hi Vivek
I appreciate for your observation of receiver behavior.But this also very short solution. You can select only listed satellites.And listed TPs only. You can't add your wished satellite and TPs.And I tried with other receiver which not supplied by Zee. In that receiver NSS 86 is not listed and not addable, so not
available.And you know always tuning your receiver to factory data and putting and selecting the TPs also cumborsome.Any your work should be apreciable.Thank you very much for your contribution.
Best regards
G.Markandeya
Vivek said:
Dear Friends,
Cowboy....O-Ha :D
Vivek
Bandit Queen
Satellite Blood
We are trying but you have any secret password please give us
markand
Hi Vivek
No, I didn't have any secret codes. If I got them I wiil deffinately share with all of you.
Best regards
G.Markandeya
Vivek
Bandit Queen
Satellite Blood
markand said:
Hi Vivek
Best regards
G.Markandeya
Hi G Markendeya,
How can I download my zenega receiver program file to my computer?
Vivek
Bandit Queen
Satellite Blood
markand said:
Hi Vivek
Best regards
G.Markandeya
Hi G Markendeya,
:confused
markand
Sorry vivek,
we are unable to to upload the program but data is possible.
markand
Vivek said:
Hi G Markendeya,
:confused
lokesh
ok thats true.
but no need to go to software upgrade section. Just simply press menu and 9009 u will get the set-to-set download window. now do as directed by vivek.and thats all.
But I think this has been described earlier by Nictus34 too.
Vivek said:
Dear Friends,
Cowboy....O-Ha :D
HellCrusher
Hi Markand,
Can you pls explain how to download the software program Zenega to PC?
If this is possible through Hyperterminal, Then plz gimme the pin-outs for Rs-232 Cable.
Is there any method, how to STOP downloading the Software automatically from satellite & upgradation procedure which converts our Receiver into Decoder!
HellCrusher
markand said:
Sorry vivek,
markand
Vivek
Bandit Queen
Satellite Blood
I know set-to-set download, but I want to know how to download software from my set to my pc.
Cowboy.......
Vivek
Bandit Queen
Satellite Blood
vek_ess
lokesh said:
ok thats true.
However, lokesh new v1.20 they already delete edit function.
Tom Robert
HI Vivek
Please read and use this thread
"ZENEGA CD -1002S software needed for Dish TV India" instead of starting repitation of one question 100 times.
All your answers and questions are in detail in this thread : ZENEGA CD -1002S software needed for Dish TV India. So use it and write there
I hope you will never mind and avoid repitition again and again of one basic question repetitation in this thread
Vivek
Bandit Queen
Satellite Blood
Tom Robert said:
HI Vivek
will you received my mail..............................?
Vivek
Bandit Queen
Satellite Blood
Dear All,
This to inform you that ZENEGA STB Model 1005 S is good for all the purposes. Its Installation function is really marbles.
Vivek
Bandit Queen
Satellite Blood
markand said:
Hi Vivek
Best regards
G.Markandeya
NO BOSS....
This is not truth , it can add or edit any TP & Sat. just checks it.
Cowboy..............
habibbullah
I have need super laser software & till me about receiver software site thire new software thinks
Vivek
Bandit Queen
Satellite Blood
Dear Habibbullah,
as to tom i think he has..........
kajoor
yes sir ur right i got ZENEGA 1005S. I CANT ABLE TO ADD TP & SYMBLE RATE ?
DOES ANYONE HAVE SOLUTION FOR THIS.
THANX
