Yes ,I tried with another receiver . All connections and calbel leads are ok. I'm 100% sure probelm in Reciever. Which IC I have to repalce I don't know. Would you help me?
Any body can tell me which IC is faulty in my receicer beausat BSR 6310CI.It has no video and audio but power is ok. All connection of the dish cables and AV /RF connections are OK.
find your answer at _www.dreamsatelectronics.com.hi ! this is anand chandvale from india.i was serching for mastercode for beausat reciever 2004 i get it from dreamsatelectronics thanks to dreamsat electronics.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
