plzzzzz. help strong 4642 , urgent..........
slugworth
gsky v7
New England
I would try clearing the nvram from the secret diag screen.
With the receiver turned off with the front panel button,press and hold the front panel power and ch up buttons at the same time until the ---- shows on the display then release. Select clear nvram from the menu.After that, cycle power with the power switch in back.When the receiver boots,you will have to select the default language ect.
sana-sat
dish size 90 cm
receiver: strong 4622ii
yemen
wow! great idea!!! it works
i dont know how to thank u my friend
wish u all the best
