Polsat Info Channel - Help!
scottishlion
motorised dish, sky box
scotland
Hi trying to find out how to get the Polsat Info channel on hotbird, I have a Dragoncam for Polsat and that seems to be working fine at the moment but I can't find Polsat Info channel even by doing a scan on the transponder! any help would be very much appreciated
arfurdaley
I think the channels called 'Info da abonentow' on the same TP as Polsat Sport. Clearing with a patched TM1500
scottishlion
scotland
Thanks have tried to get that channel but the only Info channel I get on Hotbird is showing classical music right now. Is that the channel?
josephgall
Co. Down
Sorry to change the subject but how do you enter keys into a Tm1500 to get the Polsat channels, I know where you enter the keys but how do you enter in dec keys that I have.
ginger
i am the same only gettin tv kultura on info channel. also wanting to watch the celtic match.
hightower
Technomate 1500CI+ patched reciever, NTL pace box, Smart 0.2dB titanium LNB, 80cm dish, Manhattan HH120 motor, AMD 64bit 3500+, 1GB ram, 3x120gig 1x200gig HDs.
Glasgow
Im picking up "info dla abonentow" on 12.360 (H) / 27.500 on hotbird.
At the moment there is something called TV Market showing.
I have a patched technomate 1500.
Can someone confirm this is polsat info?
ta
ginger
has anyone had any joy picking up the match??? i have got some film on the channel 12.360 (h)/27500 on hotbird????? using my dragon cam
Mickha
North West
Finally found it:
Info dla abonen 12360 H 27,500 vid 868 Aud 869 PCR 868 SID 10530
Open using Dragon
scottishlion
scotland
Mickha said:
Finally found it:
Open using Dragon
Hi quite new to this satellite game and not sure how to change sid number is it easy?
ginger
i had to delete my previous channel list on hotbird and re search them all to get the chammel. got it using dragon
scottishlion
scotland
Ok missed most of the game now will try that later on so I'm ready for the nest time thanks for your help.
john_graydon
Dublin....Ireland
Mickha said:
Finally found it:
Open using Dragon
mickha Is it clearing with anything else do you know.
Mickha
North West
Hi john_graydon,
I've only used the Dragon, of late, put away my MM and Conax Cams and numerous cards, but it's part of the Polsat package so I should assume anything that opens that package should open this channel.
Best wishes
Mickha
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
There's a patch for the Manhattan ST series which will get Polsat. That patch won't get Spice P though.
Norm
Aberdeen
Channel Master 1.2m motorised, V Box, Technomate TM-5402HD.
Aberdeen, Scotland
The TMB file on a tit card will open it in an MR or MRev.
john_graydon
Dublin....Ireland
Just tried it and still blank screen, used tmb 15/8 file wit tit card. Maybe nothing on will try it later again.
Norm
Aberdeen
Aberdeen, Scotland
John, still working OK here with MR1.18 and TMB from Fook.
john_graydon
Dublin....Ireland
Wrote fook files to tit again and no joy with M rev 224. Will wip out the tecnomate and try the card in that. Thanks Norm
