Prifix 9400 stb
Panchal
I just bought new STB Brand PRIFIX -9400 model. It has LAN Port.
There is no mention of setting procedure in Catalogue. Also in the MENU there is no mention of web server setting.
It works with some scrambled channel but every few minutes it stops with SCAMBLED message and then restarts.
I need help how to set up LAN IP address and who provide the support??
Any help is most welcome.
Best regards,
Panchal
You are on a card share. When the keys change the server is overloaded by all the thousands of requests for keys.
Unfortunately you have discovered one of the common problems with card share systems.
You can do one of three things:
1) Put up with it.
2) Find another card server to connect to
3) Buy a proper subscription to your desired provider(s)
If you want guaranteed service then you should be subscribing.
Panchal
Your quick response highly appreciated.
It seems card share system. can you please advise me how to solve the problem. I am ready to subscribe if there is any one providing service with server for uninterrupted viewing.
Do you know who provide such service???
Thanks again.
Panchal
Ive already told you how to fix the problem - buy a proper subscription to the pay tv provider you want to watch. If you dont want to pay then you do without.
As far as Im concerned pay card share servers are run buy the scum of the earth.
You wont get any advice on how to find a better one on this forum as may of the members feel the same way..
