Problem clearing Premiere...help!
perthkenny
Blade BM7000s HD receiver with Cccam/Newcamd, Acer Netbook, Netgear 3g wireless 4 port router,Time Athlon XP2400mhz Desktop. 2 x 80cm dishes- lnb1 at 13east,lnb2 at 19east, lnb3 on the 2nd dish for 28.2east Astra 2B south beam. Everything is open now
South Italy
Hi all
I'm trying to pick up the Premiere German film channels... I'm on Astra 19e. I have tuned and can see the FTA channels such as the "Portal". I know I need to manual input Nagra keys to see the encrypted channels, and I can get them from Florikey, but no joy!
I'm using a Fortec Star Platinum with the last firmware available from early this year.
Am I missing something? I'm located South Italy, using provider id 0501. Should I try another provider id?
Note, prior to D+ changing to Nagra3 earlier this year I regularly inputted manual Nagra2 keys, so the manual input method is not the problem, I know how to do it with this Fortec box.
Do I need a patch?
Any suggestions helpful. I don't think this is a decryption issue, I'm just not sure about this provider.
Thanks guys.
4dbennett
lifes not a practice run
SPIDERBOX 9000HD, 1.2 and Humax Foxsat HD,Hitachi L500HDD
Acer Aspire 5315 Lappy
torfaen south wales
perthkenny said:
Hi all
Do I need a patch?
Thanks guys.
There is a new patch, published in the usual place, its an auto update emu so i don,t know how it works with your set up, patch is backed up with softcam/keys.
dave
perthkenny
South Italy
Thanks Dave....do you mean the software site for my Fortec? Al*bar?
Last time I checked I was up to date software wise except for the last *ps AU which caused the boxes to crash!
Do you know of another which will run on my box?
Cheers K.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Cheers K.
As far as I can make out, the support for that receiver has died, unless anyone knows where to get it, as the stuff on al7bar is way out of date, and I would be surprised if it still opens anything.
Try a Diablo, or a new receiver.
perthkenny
South Italy
Yep, that's what I figured. As to a new box, I see masses of patches/emu etc for Dreambox. I might go that way if I see a reasonable deal.
Thanks Robbo71.
perthkenny
South Italy
Incidentally, the box I have has been very good at decrypting stuff so far, it's a shame the software support is no longer there. Technically it's still very capable...T*S AU causes crashes, but up to the change to Nagra3 I was still able to watch Nagra 2 taquilla etc by key inputs once or twice daily and still can get Polsat. Also there's 2 CI slots if I choose to go that route.
Shame on Fortec Star for dropping software support on a 3 year old box!
Any other info on clearing Premiere would be most appreciated, though, even a generic or adaptable patch...
Thanks, K.
Robbo
Retired Mod
Gravesend,Kent,UK
The Technomates are pretty well supported at the moment, and the Dreamboxes of course, if you like a little bit of a challenge.
perthkenny
South Italy
Which would you recommend Robbo? I don't need a hard drive, just a well supported stable (cheapish, I'm Scottish) box.
Thanks, K.
Stay away from Fortec Stars if you want to play with patches - the hobby support rarely lasts more than a year or so.
Cheap receivers - the Lidl stuff is ok if basic, and the Technomates are great little receivers.
The ulimate receivers are the Dreambox and other Linux receivers. Infinitely customisable, & superb hobby support
perthkenny
South Italy
I'm off guys, Blues Brothers is on in English on Cinemax Polsat Astra 19 East. (Nagra 2 7101/7001). Enjoy!
moosegoose
bog standard
80 cm dish hh motor teco tm1000 dreambox 7020
cas 3interface
dragon cam.promax tv explorer 2.
norwich
a ci slot might come in handy when every thing go nagra 3.the technomate 1500 ci super is very good and cheap 80 pounds.
Milkybarkid
I have it on Hotbird. :-Cbigsmil
Robbo
Retired Mod
Gravesend,Kent,UK
Well, I manage quite happily on a TM1000D super at the moment, so if you want something really cheap with good support then one of those wouldn't be too bad. Obviously the TM1500CI+ are a bit better, with the CAM and card slots. Both those models have been effectively replaced by the TM5200 and 5400CI+ respectively, equally well supported, but with USB and twice the channel capacity.
I will eventually get a Dreambox 7020 or the equivalent at a later date, but I have no need right now.
and Milkybar kid is right of course, Polsat is on 13E.:-googly
perthkenny
South Italy
Thanks guys, I'll start having a look round...on the Premiere subject, do they screen English audio movies often? That of course is the main reason why I want to look at it. I'm well out of range down here of the Brit regional providers from 28 east.
Robbo
Retired Mod
Gravesend,Kent,UK
Yes, virtually all the time, some are just in German, but there are usually some that have English audio as well.
v9oly
Dreambox 500S & 7020s. Technomate 9100 & 1500. Force frontier fixed, Raven 90 fixed, Triax 90 motorised dish. Diablo & dragon cams.
South West
Some good films on there perthkenny, lots of origional and english sountracks, see link below for more info.
h**p://www.lyngsat.com/packages/premiere.html
Regards,
Ollie
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
For English language moviers Premiere is pretty good, but Tequilla is similar. At the moment Premiere is open, but that could change soon - so make sure to get a receiver which will work with a legal subscription card as well.
