problem getting al jazeera sports +1/+2
smudgerinho
dreambox 500 c/w Fracarro Penta 85 motorised dish range from 4 deg W to 30 deg E
SCOTLAND
for some reason i'm not getting these channels just now with my al jazeera card on hotbird,just a blank screen, other FTA channels ok
is there a problem with these channels broadcasting?
if not , how can i check whether the problem is card related or not?it's a 12 month card i got in august so there should be no problem with the card
HB13DISH
Retired Mod
Middle East - Israel
Try to delete all the channels from your channels list and then rescan.
Check that all channels are back.
If they still don't open, unplug the power cord, wait few minutes, insert the card and then plug in the power cord.
Hope that this helps.
smudgerinho
SCOTLAND
thanks for the reply hb
unfortunately no success
still cant get the channels on my technomate 1500 or my dreambox 500
don't know if there's any way to check whether the card is indeed valid for 12 month or whether one just accepts it on the trust of the dealer,i'm nor sure if i can check this
it has been working fine on both recievers before xmas
dasteelman
85cm transparent dish
85cm Penta Dish (motored)
Black Ultra LNB
VU+Solo
VU+Duo
technomate 9100 linux
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
cant get them either
