Problem: Programming Titanium card with Multipro (Cardpro)
okverd
Hi guys.
Please help me. I bourght Titanium card and doesn't work with my Multipro programmer (connection: PS2 + serial port).
I using software Cardpro 1.1.1.6, and card select type: BlueCard, PIC 16F84 + 24C64, its can read and erase flash memory and internal eeprom, but with external eeproms always got error.
I tried also Cardprogger1.9.0, but its said: "ATR : No ATR ! unsupported Titanium OS found".
Please help which a software will works with Multipro programmer, or which a programmer I have to buy.
Thank you very much
turny
msn.co.uk
tyne and wear
okverd,
you need programmer in pheonix mode 3.5 mhz
i used old clanzers build 5
use prog 1.9 you will get unsupported os message
use erase button this will put card in virgin state and upgrade to os 1.06
now load flash and eep files i used mach1 files from toecutters
now click burn
now watch data flow very fast compared to fun cards
hopefully you will get success message
good luck
okverd
-=turny=- Thank you very much for your advice. I done as you wrote me and its works.
I opened software "Multipro" select:phoenix 3.58Mhz.
Then opened software Cardprogger1.9.0...and its works great.
Well done "turny"
Take care mate and thank you again
shahini
How can I get hex and eep file to program titainium cards, please can u help
