Problem with tranponder 11023 on astra 2E
aless
90 cm satellite disheartened painting to Astra 2E 2G
North West Italy
I'm having a problem in receiving the signal from transponder 11023/H/23000 on ASTRA 2E.
The signal is almost always absent; it has been happening since January.
I can receive with no problem the signal from other transponders on the same satellite.
Does anyone has the same problem?
I've a 90 cm dish and I'm located in North West Italy
According to flysat, the TPs are 11022 H 4444 and 11023 V 2500, being a Feed and Data respectively.
If you meant 11230 H, the SR is 27500.
11230 V is inactive or defunct since November 2023.
aless
North West Italy
On 11023/H/23000 it should be possible to find BBC NEWS HD, BBC RADIO 3 and BBC RADIO 4
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Welcome to the forum, @aless !
:-welcome1
It's on astra 2G according to flysat and kingofsat, and on the UK-beam, which is the spotbeam I presume?
I'm surprised that a 90cm would be enough for the UK-beam, in NW Italy.
I hope others can jump in, if it is a weak transponder, and with reception reports for that area.
BGreetz,
A33
It looks like 11023 H,23000 has left Astra.
Instead, we have a test carrier at 10729 V.
I'm sorry, I got the wrong satellite.:(
Yes, sorry - I took got the wrong Satellite!
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin + SF8008 SUPREME + Uclan Ustym 4K PRO Twin
GTMedia V8 UHD
GTMedia GTcombo x 2
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
:-welcome1
BGreetz,
A33
Not easy in Alicante, España with 1.8m.....skew setting vital. Along with 12129 V :angry::angry:......will get worse here with summer hot months.
rodscha
its 11024H 23000 and getting weaker these days,seasonal low.
I heard there s some sand in the clouds,this weakens reception even more>.
I had bbc yesternight & lost it today... maybe a comeback tomorrow
10773H 23000 is somewhat stronger...try it!
a33
XSAT410
Rebox RE-9000
The Netherlands
aless
North West Italy
I have no problem with transponders 10818/V/23000, 10847/V/23000, 11552/H/22000 ; as signalled the biggest problem is on 11023/H/23000: could it be a problem of the transponder itself? Is there anyone based in UK who is receiving a good signal from 11023/H/23000 ?
Thank you
aless
North West Italy
Thanks for the advice. I'm trrying to receive BBC NEWS HD, BBC Radio 3 and BBC radio 4 and unfortunately they seem to be only on
11023/H/23000
rodscha
bbc radios are online,just type BBC radio 3,or BBC radio 4 it will come up!!
aless
North West Italy
Yes, thanks for the advice. I know that and I'm using that as a backup solution at the moment, but from home it would be more practical for me to receive the radio stations from the satellite together the BBC TV channels (and at the moment it is possible for all the stations and channels with the exception of BBC radio 3 and 4 and BBC NEWS)
rodscha
you can plug the computer sound to a hi fi or use bluetooth.... works fine for bbc3 classical
