Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
DISH SETUP: Single sat, Multi-Sat & Motorised
Problems getting signal for Eutelsat W2 / digitalb
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="satelliteman" data-source="post: 654910" data-attributes="member: 255812"><p>The bigger the dish the better. An FR Penta85cm certainly pulls W2 in perfect if you were considering a dish change. </p><p></p><p>Ok, assuming your dish isn't damaged or warped (as mentioned in post #4), try and find 13e or 19e again and get a lock. Then use the transponder frequency mentioned above (for W2) and move the dish a very small movement depending on which satellite you have. No need to alter the dish El at this stage. This might be where your going wrong. </p><p></p><p>It's only a small movement.</p></blockquote><p></p>
[QUOTE="satelliteman, post: 654910, member: 255812"] The bigger the dish the better. An FR Penta85cm certainly pulls W2 in perfect if you were considering a dish change. Ok, assuming your dish isn't damaged or warped (as mentioned in post #4), try and find 13e or 19e again and get a lock. Then use the transponder frequency mentioned above (for W2) and move the dish a very small movement depending on which satellite you have. No need to alter the dish El at this stage. This might be where your going wrong. It's only a small movement. [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
