Przemek211
- Apr 5, 2009
- Age
- 32
80cm antenna, two LNB with DiseqC (astra + hotbird).
Skystar S2 + DVBViewer on P4 2,6GHz, 1GB RAM, HD2600XT on AGP.
- Poland
Hi, i have few problems with dvbviewer. I don't get any replies on official board
I'm using the newest version of DVBV downloaded from members section + ArcSoft codecs (and Powerdvd 9 codecs for test) and EVR. This works with Skystar S2 on the newest BDA driver. Running on Vista Home premium with all new updates. My PC conf is: P4 2,6GHz, 1GB RAM, HD2600XT on AGP.
My biggest problem: On FTA HD DVB-S(2) channels from Astra, all is good. But on hotbird only HD DVB-S FTA is ok. HD DVB-S2 is no video and audio, but signal is still ok. (beetwen 78-80% and on astra is similar) Sometimes, for approximatelly 500ms i hear sound. I'm using also local sharing in my home (it's legal in my country) and DW on HD DVB-S2 channels also go ok, but picture is black
Second, but smaller problem:
Sometimes OSD isn't started. If i change channel i don't see nether panel. If i click Esc also don't start menu and not working volume changer in scroll. I must restart app.
Third problem:
I have a two satellites config (astra + hotbird). If i open program on hotbird and next go to astra channels, DVBV view a 15% of quality signal and not view a channel. If i close program on astra, on next open all is ok. (go from astra to hb is ok, but if again go to astra i have the same problem).
Third problem:
