Problems with Titanium card
D
dr peden
nobbly said:
Some nice info on Titaniumcard programming and files
http://nowgetready.tripod.com/
nobbly
i have a axas 2 cam which has been up-graded to matrix put it does not stay on channels, i also will not de scramble hispasat and causes problems with my tit card when it is on thor the channels keep going of air, the card is ok any ideas help!
D
dr peden
i have a axas2 cam upgraded to matrix but i cannot keep the channels on i also use a tit card and even that gets blocked please advise help dr peden
weedy22
hi i got a smartmouse\phoenix burner with a titanium card.when i open the program it tels me that ATR : No ATR !
unsupported Titanium OS found.???? when i push the erase button it stops at sending trapcode it just hagns there.any one that can be so kind to help me???i also use win xp does that matter???
Go into device manager weddy22, Com ports, advanced and disable FIFO buffering. This may do the trick.
appe9
Hi Weedy22 !
I have same problem ,so have you got any information about it?? Even my smartmouse\phoenix burner not read my titanium card??? Why that, it tell´s me
that could not read cpu from card, clean kontakts. Help somebody!!!!!
peppey
did you wait for an half-hour while hanging in trapcode?
turny
msn.co.uk
tyne and wear
weedy22
that many ppl having probs with tit with all types of programmers
i beleive the problem lies in the os of this temperental card
try downloading titaniumosupdate2 from somewhere like toecutters
run this and downgade os then upgrade to 1.05 or 1.06
this seems to kick the card into life and will confirm comms between pc/programmer and card
now open prog 1.9
erase
load files
burn
hopefully the dreaded trapecode error will not appear
Razor
Retired Mod
Ireland
If you have a Force receiver you need OS 103 on the tit card. Most tit cards come with this OS.
