Prog Satellite Finder v2.01
Glenn_911
satlightning.com
Echostar 2200Ci Viaccess, Echostar 3000IP Viaccess CTech 2100Plus and M-Vision 200HD
Mainport Europe
Prog Satellite Finder - Simple and completely free the utility capable
considerably to help with adjustment of the satellite dish.
Second generation of Finder after 6 years delay.
Features:
1. Calculation of azimuth and elevation angle.
2. Indication of level of a signal, including the sound.
3. Scanner and satellite detection.
4. Control of Diseq positioner(include usals), switch .....
Moved here from satellite meters and installation. Only for ProgDVB etc.
Nice little program Glenn_911. Will be helpful I'm sure.
mozgie
SkyStar2 USb
Surbiton
Nice 1 mate! that soft is exactly what I was looking 4!
BombedOne
Republic of Georgia
The problem is, that not all cards provide signal and level readings accurately. Say, SNR change in dB from 4 to 10, may be shown only as 5% in Q change, but SNR change from 3 to 4 dB - as 40% in Q change. Also, software does not utilizes ability of some cards (older skystar, broadlogic cards) to read and display BER, SNR, error rate and so on, more advanced and practical information.
