During the OS update the programmer lost power.
I made the programmer myself and it works fine. Problem was with the f*** transformer...
After fixing the problem, new attempt, result (with TeamPDK MII 16-11-2004)
"Failed to get an ATR"
Card is m2 and dead?
Is there recovery tool for the m2? (like titanium has, have you tried tita rec. tool with m2?
Is there a way to reset the card?
Do you have any other solution in mind or should I just write to Santa and wish for a new card...
thanks!
thanks!
