program a titanium card
chaffey99
i have a titanium card,
i want to program the card,
which program is the best
thankyou philip
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
It depends on what you want to see and what files are available.
The new "Wholetthedogsout" file may be suitable for you, depends on which CAM you are using.
Don't think that they are suitable for the Matrix, but I guess that they will soon. Have a look on fookfiles.com, should be something there for you.
jagost02
Single
Yamaha YZF-R1
North of the Tejo & South of the Thames
Do the dog files work with embedded cams such as those in a SAGEM 3240 to get 30W?
Regards,
They work with embedded Seca cams, like the one on the Digiquest 2000 for S2, but not sure about the Nagra channels.
