Rock39
- Apr 3, 2004
- Age
- 59
Echostar DSB-808 Vi2
80cm Dish Motorised, temporally on a 1mt pole mount, (which tracks the arc if the wind blows the right direction.) Pace 2600 (Sky), Infinity usb+Cas3 programers.
Dell P4-2.4ghz, 512DDR, 75GB HD
Radeon 9800 Graf/Crd. + Ext HD M
- Ireland
Quite new to this but have been able to program an Opos card 1.03 using a infinity USB Unlimited to receive a few channels on my Echostar DSB-808 Vi2 using downloaded Xin1freecam Crypt files - loading the card into a Zeta Yellow Cam – The problems start when I try to run a Cw update file - if I try this in VCP mode I get a program crash every time?
I need some info to point me in the right direction – please excuse my ignorance but:
Do I need to use any other program to install the updates?
If my programmer is USB how can I select a COM port when in VCP mode?
I’ve also downloaded Naga Edit & Winex 5.42 do I need them?
I assume I can update just keys as required is this correct or do I need to enter the eprom and flash/app each time?
Is the purchase of a different cam or 1.05 Opos card required to extend the channel possibilities I updated the card to 1.04 but have since read that this makes no difference and that it is not possible to upgrade to 1.05
Any help appreciated as I’m getting more lost by the minute!
Cheers,
Cheers,
