Programming and udatind Fun 5 Card
gorbat
I am novice to programming cards and updating keys. Please can you tell me how to program Fun 5 card with Fun programmer, which software to use, because it seems that none is reading Fun 5?
After 'programming' in Fun Magic software, I put card in the reciever, but it does not read anything, also, when I wanted to edit with Editor
it can not read EEprom?
What I am doing wrong? Can you give me instructions please?
What files are you using Gorbat and what are your card settings in the programmer software?
waverider
Salty Tech Monster Bod
Protek 9750 HD IP, Spiderbox 9000HD. Cryptik Digital H-H Mount with1.2m Oval Dish and a box in the garage consisting of 2 obsolete STBs, various Cards and a couple of cams!
South East England
gorbat said:
I am novice to programming cards and updating keys. Please can you tell me how to program Fun 5 card with Fun programer, which software to use, because it seems that none is reading Fun 5?
AS Rolfw has just mentioned what files are you loading? Also with fun cards you only load the Flash and External EEp!
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
Assuming the Fun programer is the USB version (and not the parallel port one) you can use the Infinty software.
gorbat
Try to load 6 in 1 hex files.
Eeprom read 24LC256-32KB on com2.
Card is AT90(512).
There is a good tutorial on www.duwgati.com , go to Software Tutorials and then FunMagic, this may throw some light on the subject.
waverider
South East England
Yes it's best to read up on things before asking questions about them, otherwise it's a bit like a stab in the dark!
