programming funcard6 help
hussha1984
hi,
i have a elvis usb multiprogrammer 3.6 using software 1.8. i can auto detect the card and verify it but i cant erase it. when i try to erase it it gives me an error message. when i try to program wihout erasing, it loads eeprom loader successfully but when it comes to writing external eeprom it fails and give me an error message.
i used 3 different flash and eeprom files so i dont think thats the problem - any help programming my first funcard6 would be greatly appreciated
thanks in advance for your help.
Fagster
With my programmer i gotta turn the Card upside down to write to ext eeprom.. try it out.. :p
safod23
if you use LPT port on your computer you use wrong software to program the card use funprom program to do the task it is available in many versions Good Luck
