Programming
G
Gazzah
Would someone please tell me how i can use my VX multi programmer to insert the codes onto my gold card to view certain channels. I have found sites that supply the codes but i havent got a clue how you insert individual codes when programming.
Gaz
nobbly
Not in UK
Hi Gazzah,
The Vxmulti software doesn't let you insert or change the codes but you can use a software called Picbined 143 from Phils sat files.
http://phillsfiles.ubb.cc/ in the software section
nobbly :+
G
Gazzah
Thanks for your response. I have indeed downloaded the picbined143 from Phils site but can someone please explain to me how you use it?
Why are there so many different files in the picbined? Which one do i use?
Cheers
Gaz
nobbly
Not in UK
See my post on using pic bin edit
http://www.satellites.co.uk/scripts/webforum/DCForumID15/403.html
nobbly:+
G
Gazzah
I have followed your instructions but cannot work out how you choose which system. There doesnt appear to be a menu to do this. Can you help further?
Gaz
2old4this
Honorary Admin
Cloud Cuckoo Land
see recent post in the CAMS forum on using coco strings with picbinedit.
Is that what you're after?
2old
