- Mar 29, 2004
- UK
Would anyone please know if there is a button combination sequence to reboot a Promax Ranger Neo+ other than the single button press of the On/Off button on the side of the meter?
I was using the meter, wanted to switch it off and did a short duration press of the On/Off button. This brought up a small centrally located menu in the main screen. The bottom option in this menu was Exit so I pressed that to clear the pop up menu. This action has turned off the Promax screen but the meter is still running, pressing the On/Off button does nothing, will not power down and it remains powered on with a blank screen.
Any ideas apart from phoning Promax UK?
