qq box
philipg
qq box laptop running xp home, 90cm dish
central scotland
hi am using a qq box with blaze DTV 3.5,
dish set on astra 28.2, and eurobird 1, good signal and quality, when scanning for channels i cant get freesat channels, have checked that transponders for freesat are being scanned.. still no freesat... any ideas
Thanks... Phil
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Hello
Welcome to the forum philpg
Ok well the first thing that springs to mind is, you are probably pointing at the wrong satellite and you are actually seeing channels from another satellite that have the same frequency details contained in the stored channel details as details are often duplicated across the arc.
What channels are you actually receiving actually name some and do the channel logos you are seeing correspond to the channel name?
philipg
central scotland
hi, i am receiving a lot of bbc channels ie scotland, wales etc, movies for men, film 24, e4, channel 4+1, no itv channels, a lot of foreign channels.. if i connect a sky box to the dish i get all freesat channels...
I hope this helps
Cheers... Phil
philipg
central scotland
i scanned TP. 10714Mhz H 22000 5/6
the channels i received were
MMs main, 4 x unknown, sky preview, DVD extras, sky text holidays and sky preview active
Cheers
Topper
But you appear to be receiving freesat channels from the lists given So you are saying you are not getting ITV channels ? is that correct? any more you are not getting and particularly want?
Is it perhaps a case that you need to scan each freesat transponder frequency individually?
EDIT ah right I see they do not correspond with listings on lyngsat for that frequency, I had not spotted that, mmmm finger trouble or stb trouble I wonder
What is a qq box?
philipg
central scotland
i am not recieving itv channels or channel 5 , bbc scotland in fact most of freesat channels are missing, a QQ box is an external usb sat box about the size of a ciggy packet
Cheers
Topper
Has your dish been used before or have you just installed it?
what is the skew set at?
what cable has been used from the lnb?
what lnb is it?
philipg
central scotland
i dont know what the skew is set at, but on my sky box i have 80% ss and 80% quality, i have also tried the qq box at another location where the dish was set up by a sky installer.. with same results
cheers ...
Topper
cheers ...
In that case I would say the qq box itself or the software is at fault
philipg
central scotland
i have just connected a Quantum sat reciever and scanned astra 28.2and eurobird 1 and am getting all freesat channels..
that would make me believe that the dish is set correctly
i wonder if anyone has scanned for freesat using blazeDTV
Cheers...
ftodonoghue
QQ box usb DVB-S receiver. revo HTPC, FTA receiver, skybox
Ireland
Hi PhilG. I have the same setup as you with the qq box and am only receivind the same channels. Have added BBC transponders but still no joy. did you manage to get your problem sorted. Thanks
Can you go into your LNB setup and check what the Local Oscillator is set to, should be Universal 9750/10600, 22Khz switching Auto.
ftodonoghue
Ireland
Managed to get it sorted. When you are setting up the LNB, go into options I think it was and select lnb 2. a scan will result in all the freesat channels. Picked up bbc hd but it is jerky and not playing properly, must have a setting wrong somewhere.
