QualiTV boxes
moonsat777
FortecPassionHD, QualitvQS1080IR, VantageX201SCI, Motorised 1m dish, 8w to 28e
Wales
What would you say is the going rate for a Qualitv box? The QS 1080 IR.
The cards for these boxes are now defunct since the provider has moved to MPEG4 for HD. But its still good for 4:2:2 and FTA. I'm not selling, just interested to get some views.
danit
motorised Gibertini 125 - fixed dish 72 -
stabHH120 -
lnb Inverto Black Ultra 0.2 - Sharp 0.4 -
Jepssen STHD3 AzboxHD Premium / 1TB WD e-sata hdd -
Fortec Passion HD -
QUALI IRCI HDTV -
Homecast PVR 300 -
Digiscrappybox -
various CAMs -
vari
8e 43.9n
see the latest gone on ebay
item number: 330276830650 99,99 euro
i.n: 150276141431 81 euro
still good only for 4:2:2 feeds (but not dvb-s2), dunno anyone using it for regular channels
tapfit2004
lula member
livesportsontv.eu
humax 5400
fortecstar
sl65
quali tv ir
4 digiboxes
dragon cam
funcard7
sm3d12 motor
wavefrontier t90
90cm dish
1m dish
dublin, ireland
to danit.
i see you have the quali irci listed on your profile. i was wondering if you had tried an mpeg4 cam (like this one on ebay: item # 360149617205) to receive hd transmissions or maybe it wont work anyway with dvb s2.
also would you know where to pick up the irci model, as i have the ir model and all the ones i've seen on ebay are the ir model.
any help would be appreciated, thanks.
danit
stabHH120 -
Fortec Passion HD -
QUALI IRCI HDTV -
Homecast PVR 300 -
Digiscrappybox -
various CAMs -
vari
8e 43.9n
tapfit2004 said:
to danit.
no, never tried the mpeg4 cam, no use at all (even if it worked properly...) in my opinion, as the big issue actually is dvb-s2 standard and QUALI tuner is not dbv-s2, so with a mpeg4 cam you just could get dvb-s mpeg4 HD channels (a disappearing minority, see http://en.kingofsat.net/hdtv.php), and I also have a proper dvb-s2 receiver
as for the irci model, you just gotta wait and see on ebay, or wait for my receiver to go on sale ;) as I'm probably gonna get the AZBOX HD (4:2:2 compatible) in a few time
Just by chance I had one in last week. As you suggest it is a very odd spec, Irdeto embedded and MPEG2 / MPEG2HD only, and a DVI output on the back panel.
Overall the menus are rather nice and it has an OK DiSeQC 1.2 system, but it does have a limited channel capacity and the 1080 card is only likely to last until the end of the year - if you have access to 23.5 East.
The favourite listing is also strange, as it is on a per satellite system, rather than a favourite for the complete listings.
I wouldn't pay much more than £30 for it on its own, certainly no more than a cheap FTA receiver, unless you really do want to look at 4.2.2 FTA feeds, as it does little more.
colinp
1.2m motorised qualitv decoder manhatten blind search decoder echostar 3600ip
glasgow
Had 1 for around 4 years and it is good for 4;2;2 but very prone to crashing and losing channels for some reason.The AZbox is the future.
iwol
channel master 1.2m dish
technomate 6900,,and invacom 0.3 quad lnb
satlook micro
yorkshire
yep qualitv could have been a good box if software was developed further,great picture poor software,what is the azbox like anyone
danit
stabHH120 -
Fortec Passion HD -
QUALI IRCI HDTV -
Homecast PVR 300 -
Digiscrappybox -
various CAMs -
vari
8e 43.9n
couldn't agree more
this pretty new box has some absolutelt new spec (for the end user market, I mean...)
it's a HD dvb-s2 mpeg4/h.264 PVR ready (USB + Sata) linux based receiver
it has a built in Sigma SMP 8634 chipset, that means:
  • it's 1080p compatible, an absolute "premiere", no use for satellite channels yet (as none is broadcasting in 1080p, just 720p or 1080i) but it can be useful as multimedia player (DivX, XviD, MKV, AVI SSF etc.)
  • it's 4:2:2 compatible: unfortunately many tests have showed it's perfect with SD 4:2:2 feeds and with HD 720p 4:2:2 feeds but not with HD 1080i 4:2:2 feeds (similar to the multimedia player Popcorn Hour, using a Sigma SMP 8635 chipset not compatible with 4:2:2 HD 1080i), developers say it's a software limit that could be fixed in the next future, hopefully...
other issue is the lack of blind scan: btw the sat tuner is the same used by Vantage 8000 (and others similar) so it should be possible to implement bind scan feature by software update
STB is not stable yet and has many CAMs compatibility problems, but this often happens with new and innovative STB
andy8
1.25m motorised dish spiderbox 9000 technomate 5402 ,D15, azbox tbs 6925 card
scotland
i am relatively new to all this and have been watching sports feed with a quali box but most have gone on to 422 dvb s2 and i cant see them now
would i be able to see this feed with the azbox
Eutelsat W1 (10.0°E)
Frequency: 11101 - Pol: V - SR: 14400 - FEC: 2/3
Category: Sport - Tennis
Transmitted in: MPEG-2 4:2:2
Comments: ATP 1000 Madrid muxx in SD/dvb-s2
Not according to an earlier comment from danit:
danit
stabHH120 -
Fortec Passion HD -
QUALI IRCI HDTV -
Homecast PVR 300 -
Digiscrappybox -
various CAMs -
vari
8e 43.9n
yes, it's accessible with the AZBOX as it's in SD, only limitation is 4:2:2 HD 1080i
andy8
scotland
thanks for the reply
ive had a look online for one and there are 2 diff kinds i only want to watch sports feeds can you recommend which one i go for
2 results found for "azbox"
Page 1 of 1 1
AZBox HD Elite Linux LAN PVR
SKU: Elite
£259.00
Manufacturer: AZBox
SKU: Premium
AZBox HD Premium Linux LAN PVR
Available NOW! Very limited numbers though!
£329.00
also it had this on the website
Additional DVB-S/S2, DVB-C/C2 and DVB-T/T2 tuners will be available to buy mid March.
Note: Software is still in Beta form and will not be polished off until Mid Year
would i be better waiting untill later to buy one
danit
stabHH120 -
Fortec Passion HD -
QUALI IRCI HDTV -
Homecast PVR 300 -
Digiscrappybox -
various CAMs -
vari
8e 43.9n
£259.00
£329.00
Premium has:
- sata connection for internal HDD (Elite just USB for external HDD)
- wireless (Elite just via samba)
- higher price
AZBox HD Elite Linux LAN PVR £259.00
Available NOW! Very limited numbers though! £329.00
At those prices, go get a PCi card.
