Questions for the Cam experts
Samba65
Hi everybody, My question is this. I am looking around to buy a new ci cam but not sure which one is the best choice. Maybe you can give me some advice. I have been reading alot of info on this site about the Magic Module and Matrix Reloaded and the Dragon Cam. All seem what I am looking for. I also think I might need to get a titanium card. I would like to get channels off of Polsat(nagra) and maybe conax or seca2 that is out for the Dragon cam.
Here is the question. How should I proceed? Should I get a Magic, Matrix Reloaded or a Dragon Cam? Which one uses the titanium card and would I need a titanium card anyway? Also what is the recommended programmer for the cam of your choice and the titanium card?
One last thing to consider.......Sorry for so many questions. I have a Humax 5400z and I dont want to buy something that has compatability problems. Which cam works well with the Humax 5400? Could you not use a titanium card in the humax by itself with the allcam?
Thanks to all who can help me out. Like I said before I have been looking over this forum for hours on these questions.
Thanks again,
Samba65
Razor
Retired Mod
Ireland
The Dragon Cam is hot now....Will do seca2....and everything else. No card needed. This cam comes with a loader, if you order this cam ask them what you need to load the loader. Later on you can always add a tit card if you want...But why, The dragon will do all.
Samba65
Hey Razor, What files do you put on the Dragon cam. Do I use the magic or matrix files? I dont use fun 6 in 1 files.....what type of file does the dragon cam use. Do you know of any good sites for info on the dragon cam?
Samba65
The Dragon CAM has its own file. You can get the loader utility and file from Satdudez and Toecutters.
ZONA
hi rolfw
all went well with season interface.. THANKS but now i order the dragon cam + loader need to know which sorfware to put in the dragon cam ? for conax....hispasat..SECA.2
THANKS
ZONA
Nismo400R
Follow, Follow
Manchester UK
for some reason I cant access fookfiles.com?? is any1 else having any problems??
Razor
Retired Mod
Ireland
Yes I had, it was OK a while ago.
I know they are moving to a new site soon, maybe wait and see later.
Razor
Retired Mod
Ireland
Just had a look and had no problem getting in.
BTW, a bit OT but what is...The Mighty Bosom!!! This caught my eye when at the Above site.
It's a Titanium multi-encryption file, haven't tried it yet, too many other things on the go, but may do this weekend. :)
NAFEES
roflw,
i have a receiver(no brand name mentioned) provided by showtime it an irdeto without any ci cam just a card slot, which i can use only original no other cards can be used on this.how can i modify to use fun card.
peppey
the mighty bosom appears to be an alternative programmer to the prog.1.10. Of course I could be wrong.
