I
i wear flares
I've just set up a system - nokia SAT780 box with tv & video.
My tv aerial coax ( soldered connections - much better ! ) runs into the sat box - then into tv & vid.
BBC1 & 2 , C4 and itv absolutely PERFECT - Channel 5 unwatchable. ( white noise, you can just make out the picture )
When the coax is plugged directly into the tv or vid - Channel 5 is perfect !
Any obvious reason ?
PS Can anyone work out "Powermid" 4 in 1 remotes - I can't seem to enter ANY codes... ( nor can I confirm any.. ?? )
